Mac mini Late 2012 RAM Replacement
crwdns2869540:0crwdne2869540:0: 153K
8
69
331
152.699
crwdns2955950:0crwdne2955950:0: 28
crwdns2960004:021crwdne2960004:0, crwdns2960008:07crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 187
crwdns2959974:0187crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 75
crwdns2959982:075crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 5 - 15 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
crwdns2862627:0crwdne2862627:0
crwdns2862628:0crwdne2862628:0
Removing the RAM is an easy task that requires no tools.
crwdns2959948:0crwdne2959948:0
crwdns2959952:0crwdne2959952:0
    1. Mac mini Late 2012 RAM Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini Late 2012 RAM Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Place your thumbs in the depressions cut into the bottom cover.
      • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
      • You do not need to apply much downward pressure while turning.
    2. Mac mini Late 2012 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
      • Remove the bottom cover and set it aside.
    1. Mac mini Late 2012 RAM Replacement, RAM: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini Late 2012 RAM Replacement, RAM: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Release the tabs on each side of the RAM chip by simultaneously pushing each tab away from the chip.
      • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
      • After the RAM chip has popped up, pull it straight out of its socket.
      • Repeat this process if a second RAM chip is installed.
crwdns2935229:0187crwdne2935229:0
Andrew Optimus Goldheart
crwdns2935283:010/17/09crwdne2935283:0
516.506 crwdns2915208:0crwdne2915208:0
crwdns2935297:0405crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:072.954crwdne2935297:0
crwdns2947412:07crwdne2947412:0
So if I were to replace the Ram on my mac mini I would only have the option to choose between the 2 gb chip or the 4gb chip? I know dumb question lol.
Bianca - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
2x8GB is as much as those motherboards can handle.
Kevin Shaffer - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Dear everyone,
Does this mac mini accept :
KINGSTON DDR3 PC3-12800 - 2 x 4 Go (8 Go) 1600 MHZ - CAS 10 - HyperX Fury Black Series
Thank you.
Marouane - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I always consult Crucial's memory configuration tool. For a late-2012 Mac mini, see http://www.crucial.com/usa/en/compatible....
According to them, this Mac can go up to 16GB (2 SO-DIMMs of 8GB each). The SO-DIMMs should be DDRL3L-1600 (DDR3L PC3L-12800, CL=11, unbuffered, non-ECC, DDR3L-1600, 1.35v)
The SO-DIMMs you mentioned seem like they should be compatible (CL=10 should work fine in a computer that can accept CL=11). But I would only buy from a vendor that has a compatibility guarantee. If there's a problem, I would want to be able to return them for a refund.
David Charlap - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The SODIMMs don't need to be low voltage DDR3L (i.e. 1.35 volt). In fact Apple recommends (https://support.apple.com/en-gb/HT202593) regular 1.5 volt DDR3 and most late 2012 Mac Minis were shipped with it. So is Crucial wrong? The truth is that either will work.
John Morley - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 69
crwdns2936753:030crwdne2936753:0 331
crwdns2959996:0crwdne2959996:0 152,699
