Use this guide to replace your mini's heat sink. Reinstalling the heat sink will require a new layer of thermal paste.
Place your thumbs in the depressions cut into the bottom cover.
Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
Tilt the mini enough to allow the bottom cover to fall away from the outer case.
Remove the bottom cover and set it aside.
Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
Lift the fan out of the mini for enough clearance to access its connector.
Grab all the wires at once and gently pull straight up to disconnect the fan from the logic board.
Remove the fan.
Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
Lift the cowling from the end nearest the antenna plate.
Rotate the cowling away from the outer case and remove it from the mini.
Remove the following screws securing the antenna plate to the mini:
Two 6.6 mm T8 Torx screws
Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either screwdriver will work)
When putting back together:
Slightly lift the antenna plate from the end closest to the RAM.
Carefully pull the antenna plate away from the circular rim of the outer case.
Use the tip of a spudger to carefully pry the antenna connector up from its socket on the AirPort/Bluetooth board.
Remove the antenna plate from the mini.
Use the flat end of a spudger to pry the hard drive connector up from its socket on the logic board.
Use the tip of a spudger to lift the IR sensor connector up and out of its socket on the logic board.
Remove the following three screws:
One 5.0 mm T8 Torx or 2.0 mm Hex screw (either screwdriver will work)
One 16.2 mm T6 Torx screw
One 26 mm T6 Torx standoff
crwdns2935267:0crwdne2935267:0Mac mini Logic Board Removal Tool$4.99
Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the top side of outer case below the logic board before proceeding.
Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
Remove the Mac mini Logic Board Removal tool.
Pull the I/O board/logic board assembly out of the outer case enough to access the power connector.
Use your fingers to disconnect the DC-In cable from the logic board.
Pull the power cable connector toward the front side of the mini.
Carefully slide the logic board assembly out of the mini, minding any cables that may get caught.
Remove the following two screws securing the speaker to the logic board assembly:
One 3.5 mm T6 Torx screw
One 3.7 mm T6 Torx screw
Carefully lift the speaker wires upward to lift the speaker connector up and out of its socket on the logic board.
Lift and remove the speaker away from the logic board.
Remove the single 5 mm T6 Torx standoff from the heat sink near the edge of the logic board.
Remove the following screws securing the heat sink to the logic board:
Four 8.6 mm T8 Torx screws
One 2.6 mm T6 Torx screw
Remove the heat sink from the logic board, minding any cables that may get caught.
To reassemble your device, follow these instructions in reverse order. Be sure to follow our thermal paste guide to reapply the thermal compound on the CPU.
crwdns2935229:016crwdne2935229:0
crwdns2947412:05crwdne2947412:0
When reinstalling the heatsink the Platform controller chip has a huge gap, so you have to either use a thermal pad, ton of thermal paste or shim the gap. I ended up using a shim made out of a soda can. I posted photos here:
Victor - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
There is no need for the controller to be cooled. It is the same with the MacBooks of that time. The controller chip isnt even covered by the heatsink.
Fred - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hello,
I'll refresh this thread a bit - I replaced the thermal paste on the processor and since then my Mac mini patch 2012 has been raging at tepmperatures between 70 and 100 degrees. What could I have screwed up? The system laughs like crazy, I rebooted and PRAM and SMC and tried with SAFE MODE , changed the paste again and same thing. Do you have any experience with this type of problem?
tom - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
@tom46654 I'm experiencing exactly the same problem. After replacing the thermal paste on my Late 2012 Mac mini, the CPU temperature is around 70–75 °C at idle and can reach 99–100 °C under heavy load. The room temperature is only about 22 °C.
I've also reapplied the thermal paste, but it made no difference. I'm starting to suspect that the heatsink may not be making proper contact with the CPU, possibly due to one of the four mounting screws/standoffs.
Did you ever find out what was causing the problem in your case?
bognarb90 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
@bognarb90 To be honest, I never actually solved that problem; I’ve got a completely different computer now. I managed to bring the temperatures down on my old mini by using a fan from a MacPro 6.1 and a Noctua NA-FC1. The temperatures dropped as low as 20 degrees, but the fan was picking up dust even from the neighbouring houses ;) In my opinion, increasingly demanding operating systems (I was using OCLP) consume more resources and place a greater strain on components that were built for older, less demanding systems. I don’t think there’s a happy medium – it’s DIY all the way.
Nidec fan from Apple Pro 2013 is easy for soldering and converting for that new role as a additional fan.
