Adding more RAM to your Mac Pro is easy and requires no tools. Use this guide to soup up your Pro.
Slide the lock switch to the right, to the unlocked position.
Lift the outer case straight up off the Mac Pro.
Using two hands, pull the desired RAM module straight out of its slot.
crwdns2935229:041crwdne2935229:0
crwdns2947412:07crwdne2947412:0
How much RAM can I add? I saw Apple offering 64G, but also saw OCW offering 128G - is the CPU/MMU able to really handle this?
Using Intel ARK to compare here is what they can support!
For the 4 Core CPU Supports: 256 GB
For the 6 Core CPU Supports: 256 GB
For the 8 Core CPU Supports: 768 GB
For the 12 Core CPU Supports: 768 GB
I would add this to the previous reply : what can you do with 768GB RAM that your 64/128GB mac can't handle ?
If I am only installing two sticks of ram, does anyone have a suggestion for what slots I should install them into? Thanks for yet another great guide! -George
I have the same question and can't find an answer online. Apple doesn't ship them with less than 3 populated.
JRBv3 -
