Mac Pro Late 2013 Graphics Card Replacement
  1. Mac Pro Late 2013 Graphics Card Replacement, Outer Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac Pro Late 2013 Graphics Card Replacement, Outer Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the lock switch to the right, to the unlocked position.
  2. Mac Pro Late 2013 Graphics Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac Pro Late 2013 Graphics Card Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac Pro Late 2013 Graphics Card Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the outer case straight up off the Mac Pro.
    • It may help to push down on the center of the fan while lifting the case up.
  3. Mac Pro Late 2013 Graphics Card Replacement, Fan Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac Pro Late 2013 Graphics Card Replacement, Fan Assembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac Pro Late 2013 Graphics Card Replacement, Fan Assembly: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
  4. Mac Pro Late 2013 Graphics Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac Pro Late 2013 Graphics Card Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The fan assembly is attached to the rest of the computer by two cables on the IO board side.
    • Tilt the assembly up away from the IO board.
    • Do not try to remove the fan assembly yet, as it is still attached by two cables.
  5. Mac Pro Late 2013 Graphics Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
    • These screws are captive in the Mac Pro. Do not try to remove these screws from your Mac Pro.
  6. Mac Pro Late 2013 Graphics Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
  7. Mac Pro Late 2013 Graphics Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac Pro Late 2013 Graphics Card Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
  8. Mac Pro Late 2013 Graphics Card Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the fan assembly antenna cable from the IO board.
    • Remove the fan assembly from the Mac Pro.
  9. Mac Pro Late 2013 Graphics Card Replacement, Lower Case: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac Pro Late 2013 Graphics Card Replacement, Lower Case: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac Pro Late 2013 Graphics Card Replacement, Lower Case: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the Mac Pro upside down, 180 degrees.
    • Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case.
  10. Mac Pro Late 2013 Graphics Card Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac Pro Late 2013 Graphics Card Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the lower case up and remove it from the Mac Pro.
  11. Mac Pro Late 2013 Graphics Card Replacement, Graphics Card: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac Pro Late 2013 Graphics Card Replacement, Graphics Card: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
  12. Mac Pro Late 2013 Graphics Card Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac Pro Late 2013 Graphics Card Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac Pro Late 2013 Graphics Card Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently separate the other side as well.
    • Flip the connector up and out of the way of the graphics card.
  13. Mac Pro Late 2013 Graphics Card Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 6.6 mm T8 Torx Security screws securing the GPU to the Mac Pro.
    • These screws fit into power cables behind the GPU. Be careful not to over-tighten and twist the cables.
  14. Mac Pro Late 2013 Graphics Card Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 8.4 mm T10 screws from the GPU heat sink bracket.
  15. Mac Pro Late 2013 Graphics Card Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the GPU heat sink bracket.
  16. Mac Pro Late 2013 Graphics Card Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac Pro Late 2013 Graphics Card Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac Pro Late 2013 Graphics Card Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The graphics card is now held onto the central heat sink by thermal compound.
    • You may need to pry very gently with a spudger to separate the card from the heat sink.
    • Remove the graphics card from the heat sink.
  17. Mac Pro Late 2013 Graphics Card Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • During reassembly, be sure to clean off and replace the thermal compound. Use our Applying Thermal Paste guide if you require assistance.
    • Repeat this procedure if you wish to remove the secondary graphics card.
crwdns2935229:046crwdne2935229:0
Andrew Optimus Goldheart
crwdns2935283:010/17/09crwdne2935283:0
509.841 crwdns2915208:0crwdne2915208:0
crwdns2935297:0407crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020.889crwdne2935297:0
crwdns2947412:020crwdne2947412:0
hey! is it possible to upgrade the GPU or is this just for replacing exactly the same part?
Ben - crwdns2934203:0crwdne2934203:0
I am guessing you can upgrade them with OEM parts, but where would we find them?
Fernando Bernardino -
Yes. I recently swapped out D300 pairs for D700 pairs without a blip. I did an NVRAM reset afterwards just to be safe.
Technology Research -
I have the D300s, and would like to upgrade to the D500s or D700s. Where might I find the replacement graphics cards? Also, any recommendations on service providers who would do this procedure?
Chris M Balz - crwdns2934203:0crwdne2934203:0
I'd love to know this as well. The only reason I picked up the ,ad pro was the potential for upgrades. As it turns out D300s are crap. I can't even run boot camp properly.
jerimiahy -
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 105
crwdns2936753:030crwdne2936753:0 541
crwdns2942667:0crwdne2942667:0 109,340
