crwdns2959928:0crwdne2959928:0 ↓Use this guide to replace either of the dual graphics cards in your Mac Pro. The procedure is shown on one card, but it is essentially identical for either.
When you're replacing your card, be sure to reapply a layer of thermal compound.
Before beginning any work on your Mac Pro: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
Spudger4.9
Slide the lock switch to the right, to the unlocked position.
Lift the outer case straight up off the Mac Pro.
Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
Tilt the assembly up away from the IO board.
While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
Disconnect the fan assembly antenna cable from the IO board.
Remove the fan assembly from the Mac Pro.
Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case.
Carefully lift the lower case up and remove it from the Mac Pro.
Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
Gently separate the other side as well.
Flip the connector up and out of the way of the graphics card.
Remove the two 6.6 mm T8 Torx Security screws securing the GPU to the Mac Pro.
Remove the four 8.4 mm T10 screws from the GPU heat sink bracket.
Remove the graphics card from the heat sink.
crwdns2935229:050crwdne2935229:0
crwdns2947412:021crwdne2947412:0
hey! is it possible to upgrade the GPU or is this just for replacing exactly the same part?
Ben - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I am guessing you can upgrade them with OEM parts, but where would we find them?
Fernando Bernardino - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Yes. I recently swapped out D300 pairs for D700 pairs without a blip. I did an NVRAM reset afterwards just to be safe.
Technology Research - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have the D300s, and would like to upgrade to the D500s or D700s. Where might I find the replacement graphics cards? Also, any recommendations on service providers who would do this procedure?
Chris M Balz - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I'd love to know this as well. The only reason I picked up the ,ad pro was the potential for upgrades. As it turns out D300s are crap. I can't even run boot camp properly.
jerimiahy - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
