Mac Pro First Generation Hard Disk Drive (HDD) Replacement
crwdns2869540:0crwdne2869540:0: 27 тыс.
5
44
178
27 187
crwdns2959984:0crwdne2959984:0: 10
crwdns2959974:010crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 5
crwdns2959982:05crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 5 - 10 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
Replacing the hard drive is straight forward and all you need is a Phillips head screw driver. Use this guide to replace a hard drive in your Mac Pro.
IMPORTANT
Make sure you back up your files onto the replacement hard drive before swapping in the machine. If switching to a brand new hard drive you will probably have to re install your operating system in order to keep your computer running as usual.
Also be careful with your hard drive as damaging it can mean that you lose your files.
    1. Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Case Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the lever to unlock the case.
    2. Mac Pro First Generation Hard Disk Drive (HDD) Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      Anti-Static Wrist Strap
      $7.95
      • Remove the side panel of the Mac Pro.
      • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
    1. Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Locate the Hard Drive Bays: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the desired hard drive bay after opening the case .
      • This is usually the drive closest to the front of the case.
    2. Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove the Hard Drive Bay: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove the Hard Drive Bay: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove the Hard Drive Bay: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Make sure that the clip used to release the side panel is open or the Hard Drive bays won't slide out
      • Pull the Hard Drive straight out by grabbing the metal sled from the bottom. It may be hard to pull out at first, but after it gets released the sled shouldn't take a lot of effort to remove.
    3. Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove metal Hard Drive sled: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove metal Hard Drive sled: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove metal Hard Drive sled: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • When handling the hard drive hold it by the sled or sides be sure not to touch the green circuit board visible in all 3 pictures.
      • Locate the four 6-32 type screws on the Hard Drive sled.
      • Using a Phillips head screw driver remove the four screws and separate the metal sled from the Hard Drive
crwdns2935229:010crwdne2935229:0
Charlie Franklin
crwdns2935283:010/12/14crwdne2935283:0
1 176 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-24, Maness Fall 2014 crwdns2935289:0Cal Poly, Team 6-24, Maness Fall 2014crwdne2935289:0
CPSU-MANESS-F14S6G24
crwdns2936753:07crwdne2936753:0 44
crwdns2936753:030crwdne2936753:0 178
crwdns2959996:0crwdne2959996:0 27,187
