MSI VR601 WiFi card Replacement
  1. MSI VR601 WiFi card Replacement, Open the back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI VR601 WiFi card Replacement, Open the back cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Start by taking out the battery and charger. No power should be connected.
    • Unscrew the 4 Phillips #1 screws marked in the photo.
    • This screw is hidden under the Warranty void sticker!
    • All screws are the same length, so don't worry about mixing them up
    • Use a spudger or your finger to gently but firmly open the cover.
    • It's stuck in there with clips, so be a little careful. (Remember; If you feel like you're using too much force, you probably are).
  2. MSI VR601 WiFi card Replacement, Identify the WiFi card and remove: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI VR601 WiFi card Replacement, Identify the WiFi card and remove: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The WiFi card has two antenna cables (one white and one black).
    • Use a spudger to carefully unhook the antenna contacts.
    • Unscrew the Phillips #0 screw holding the WiFi card down. (This is not the same screw as the others).
  3. MSI VR601 WiFi card Replacement, Replace WiFi card: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the old card out of the mini PCI Express slot, and replace with a new and compatible card.
    • In my case I only had a direct replacement, which only supports 802.11b/g standards.
Geir Ove Andersen
crwdns2935283:006/06/22crwdne2935283:0
8,268 crwdns2915208:0crwdne2915208:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0328crwdne2931471:0
crwdns2935297:01,442crwdne2935297:0
crwdns2942667:0crwdne2942667:0 455
