MSI MS-1782 Motherboard Replacement
  1. MSI MS-1782 Motherboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
  2. MSI MS-1782 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
  3. MSI MS-1782 Motherboard Replacement, Wi-Fi Card: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement, Wi-Fi Card: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement, Wi-Fi Card: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to detach the two antenna cables from the Wi-Fi card.
  4. MSI MS-1782 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 5 mm screw holding the Wi-Fi card in place with a JIS #1 screwdriver.
  5. MSI MS-1782 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Wi-Fi card at its angle.
  6. MSI MS-1782 Motherboard Replacement, Cooling Assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement, Cooling Assembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement, Cooling Assembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the captive screw on the left side of the left fan using a JIS #2 screwdriver.
    • Remove the 5.1 mm screw on the right side of the left fan using a JIS #2 screwdriver.
  7. MSI MS-1782 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently detach the fan connector.
    • Remove the fan by lifting it out of its housing.
    • Be sure to handle the wire delicately; if not it will break.
  8. MSI MS-1782 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the captive screw on the top of the right fan using a JIS #2 screwdriver.
    • Remove the 3.6 mm screw on the bottom of the right fan using a JIS #2 screwdriver.
  9. MSI MS-1782 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  10. MSI MS-1782 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the eight captive screws holding the heat sink in place using a JIS #2 screwdriver.
    • Be sure to follow the numbers that are next to the screws on the heatsink. This evenly removes pressure on the components when removing the heatsink.
  11. MSI MS-1782 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the heat sink and then pull forwards towards you.
  12. MSI MS-1782 Motherboard Replacement, Battery: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement, Battery: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement, Battery: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 5.5 mm screws holding the battery frame in place using a JIS #1 screwdriver.
    • Gently disconnect the cable connecting the M.2 caddy to the motherboard.
  13. MSI MS-1782 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 3.6 mm screw holding the M.2 caddy in place using a JIS #1 screwdriver.
  14. MSI MS-1782 Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently disconnect the two blue ribbons.
  15. MSI MS-1782 Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 5.1 mm screw holding in the disk reader using a JIS #1 screwdriver.
    • Use an iFixit opening tool to push the back of the disk reader to push it out of the laptop's chassis.
  16. MSI MS-1782 Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pull the disc reader out of the laptop.
    • Lift the plastic cover and disconnect the cable connected next to the speaker.
  17. MSI MS-1782 Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 5 mm screws holding the frame in place using a JIS #1 screwdriver.
  18. MSI MS-1782 Motherboard Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry up on the battery frame with an opening tool and unclip from the main chassis, working your way around the laptop.
    • To remove the battery, pry up on it to unstick the adhesive.
    • A little Isopropyl alcohol under the battery can help unstick it from the frame.
  19. MSI MS-1782 Motherboard Replacement, Motherboard: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement, Motherboard: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement, Motherboard: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the five 5.6 mm screws holding the motherboard in place using a JIS #1 screwdriver.
    • Disconnect the display, keyboard, trackpad, and USB daughterboard ribbon connectors from the motherboard.
    • Before disconnecting the ribbon cables, lift the black tab before pulling the blue tabs on the cables.
    • Do not pull the cables out of the connector before lifting the black tab. Damage can occur to connector if not done so.
  20. MSI MS-1782 Motherboard Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two screws holding the sound daughterboard in place.
    • Disconnect the cable attached to the board.
    • The daughterboard is still connected to the laptop so just place it to the right.
  21. MSI MS-1782 Motherboard Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the daughterboard and turn it to the back.
    • Lift the clear tape and pull the connector straight back to disconnect the daughterboard.
  22. MSI MS-1782 Motherboard Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the USB daughterboard from the motherboard.
    • The orange ribbon cable is attached to the underside of the motherboard so it will stay attached when removing the motherboard.
  23. MSI MS-1782 Motherboard Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI MS-1782 Motherboard Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the motherboard, lift it vertically out of the chassis.
Joshua Pizzo
crwdns2935283:003/08/23crwdne2935283:0
438 crwdns2915208:0crwdne2915208:0
University of New Orleans, Team 4-4, McDonald Spring 2023 crwdns2935289:0University of New Orleans, Team 4-4, McDonald Spring 2023crwdne2935289:0
UNO-MCDONALD-S23S4G4
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 445
