This guide will cover the replacement of the motherboard in the MSI MS-1782 laptop. This part of the laptop is responsible for connecting all the processes of the MSI MS-1782. Check out the troubleshooting page if your laptop is having charging related issues.
When working on the laptop make sure to disconnect the battery first. Also be sure to disconnect all the ribbon cables before removing the motherboard. There are separate daughterboards for various I/O and those have to be disconnected for removal as well. Lastly the display cable is the most fragile so be extra careful with that one.
Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
Use an iFixit opening pick to unclip the bottom cover.
After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
Use the flat end of a spudger to detach the two antenna cables from the Wi-Fi card.
Remove the 5 mm screw holding the Wi-Fi card in place with a JIS #1 screwdriver.
Loosen the captive screw on the left side of the left fan using a JIS #2 screwdriver.
Remove the 5.1 mm screw on the right side of the left fan using a JIS #2 screwdriver.
Gently detach the fan connector.
Remove the fan by lifting it out of its housing.
Loosen the captive screw on the top of the right fan using a JIS #2 screwdriver.
Remove the 3.6 mm screw on the bottom of the right fan using a JIS #2 screwdriver.
Loosen the eight captive screws holding the heat sink in place using a JIS #2 screwdriver.
Gently lift the heat sink and then pull forwards towards you.
Remove the four 5.5 mm screws holding the battery frame in place using a JIS #1 screwdriver.
Gently disconnect the cable connecting the M.2 caddy to the motherboard.
Remove the 3.6 mm screw holding the M.2 caddy in place using a JIS #1 screwdriver.
Gently disconnect the two blue ribbons.
Remove the 5.1 mm screw holding in the disk reader using a JIS #1 screwdriver.
Use an iFixit opening tool to push the back of the disk reader to push it out of the laptop's chassis.
Gently pull the disc reader out of the laptop.
Lift the plastic cover and disconnect the cable connected next to the speaker.
Remove the five 5 mm screws holding the frame in place using a JIS #1 screwdriver.
Pry up on the battery frame with an opening tool and unclip from the main chassis, working your way around the laptop.
To remove the battery, pry up on it to unstick the adhesive.
Remove the five 5.6 mm screws holding the motherboard in place using a JIS #1 screwdriver.
Disconnect the display, keyboard, trackpad, and USB daughterboard ribbon connectors from the motherboard.
Remove the two screws holding the sound daughterboard in place.
Disconnect the cable attached to the board.
Lift the daughterboard and turn it to the back.
Lift the clear tape and pull the connector straight back to disconnect the daughterboard.
Disconnect the USB daughterboard from the motherboard.
To remove the motherboard, lift it vertically out of the chassis.
