MSI MS-1782 GPU Replacement
    1. MSI MS-1782 GPU Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
      • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
    2. MSI MS-1782 GPU Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 GPU Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 GPU Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use an iFixit opening pick to unclip the bottom cover.
      • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
      • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
    1. MSI MS-1782 GPU Replacement, Cooling Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 GPU Replacement, Cooling Assembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 GPU Replacement, Cooling Assembly: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Loosen the captive screw on the left side of the left fan using a JIS #2 screwdriver.
      • Remove the 5.1 mm screw on the right side of the left fan using a JIS #2 screwdriver.
    2. MSI MS-1782 GPU Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 GPU Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 GPU Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently detach the fan connector.
      • Remove the fan by lifting it out of its housing.
      • Be sure to handle the wire delicately; if not it will break.
    3. MSI MS-1782 GPU Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 GPU Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 GPU Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Loosen the captive screw on the top of the right fan using a JIS #2 screwdriver.
      • Remove the 3.6 mm screw on the bottom of the right fan using a JIS #2 screwdriver.
    4. MSI MS-1782 GPU Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 GPU Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 GPU Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    5. MSI MS-1782 GPU Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 GPU Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 GPU Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Loosen the eight captive screws holding the heat sink in place using a JIS #2 screwdriver.
      • Be sure to follow the numbers that are next to the screws on the heatsink. This evenly removes pressure on the components when removing the heatsink.
    6. MSI MS-1782 GPU Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 GPU Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 GPU Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently lift the heat sink and then pull forwards towards you.
    1. MSI MS-1782 GPU Replacement, GPU: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 GPU Replacement, GPU: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 GPU Replacement, GPU: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the two 5.0 mm screws holding the GPU by using a JIS #1 screwdriver.
    2. MSI MS-1782 GPU Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 GPU Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 GPU Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently lift the GPU and pull to remove it from the laptop.
Enmanuel Mota
crwdns2935283:003/08/23crwdne2935283:0
229 crwdns2915208:0crwdne2915208:0
University of New Orleans, Team 4-4, McDonald Spring 2023 crwdns2935289:0University of New Orleans, Team 4-4, McDonald Spring 2023crwdne2935289:0
UNO-MCDONALD-S23S4G4
crwdns2935297:084crwdne2935297:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 74
crwdns2942667:0crwdne2942667:0 981
