MSI MS-1782 Battery Replacement
  1. MSI MS-1782 Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
  2. MSI MS-1782 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
  3. MSI MS-1782 Battery Replacement, Cooling Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement, Cooling Assembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement, Cooling Assembly: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the captive screw on the left side of the left fan using a JIS #2 screwdriver.
    • Remove the 5.1 mm screw on the right side of the left fan using a JIS #2 screwdriver.
  4. MSI MS-1782 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently detach the fan connector.
    • Remove the fan by lifting it out of its housing.
    • Be sure to handle the wire delicately; if not it will break.
  5. MSI MS-1782 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the captive screw on the top of the right fan using a JIS #2 screwdriver.
    • Remove the 3.6 mm screw on the bottom of the right fan using a JIS #2 screwdriver.
  6. MSI MS-1782 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  7. MSI MS-1782 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the eight captive screws holding the heat sink in place using a JIS #2 screwdriver.
    • Be sure to follow the numbers that are next to the screws on the heatsink. This evenly removes pressure on the components when removing the heatsink.
  8. MSI MS-1782 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the heat sink and then pull forwards towards you.
  9. MSI MS-1782 Battery Replacement, Battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement, Battery: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement, Battery: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 5.5 mm screws holding the battery frame in place using a JIS #1 screwdriver.
    • Gently disconnect the cable connecting the M.2 caddy to the motherboard.
  10. MSI MS-1782 Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 3.6 mm screw holding the M.2 caddy in place using a JIS #1 screwdriver.
  11. MSI MS-1782 Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently disconnect the two blue ribbons.
  12. MSI MS-1782 Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 5.1 mm screw holding in the disk reader using a JIS #1 screwdriver.
    • Use an iFixit opening tool to push the back of the disk reader to push it out of the laptop's chassis.
  13. MSI MS-1782 Battery Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pull the disc reader out of the laptop.
    • Lift the plastic cover and disconnect the cable connected next to the speaker.
  14. MSI MS-1782 Battery Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 5 mm screws holding the frame in place using a JIS #1 screwdriver.
  15. MSI MS-1782 Battery Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI MS-1782 Battery Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry up on the battery frame with an opening tool and unclip from the main chassis, working your way around the laptop.
    • To remove the battery, pry up on it to unstick the adhesive.
    • A little Isopropyl alcohol under the battery can help unstick it from the frame.
Enmanuel Mota
crwdns2935283:003/08/23crwdne2935283:0
229 crwdns2915208:0crwdne2915208:0
University of New Orleans, Team 4-4, McDonald Spring 2023 crwdns2935289:0University of New Orleans, Team 4-4, McDonald Spring 2023crwdne2935289:0
UNO-MCDONALD-S23S4G4
crwdns2942667:0crwdne2942667:0 781
