MSI Katana 15 B13VEK RAM Replacement
  1. MSI Katana 15 B13VEK RAM Replacement, RAM: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI Katana 15 B13VEK RAM Replacement, RAM: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the laptop in front of you with the screen hinges facing away from you.
  2. MSI Katana 15 B13VEK RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI Katana 15 B13VEK RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop over so the screen is face down with the hinges facing away from you.
    • Remove the thirteen 12.7 mm screws from the bottom cover of the laptop using a Phillips #00 screwdriver.
  3. MSI Katana 15 B13VEK RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull the bottom cover away from the laptop.
    • Warning: When having your laptop's hardware exposed like this, be careful to not spill or touch anything unnecessary as damage could easily be done to the system.
  4. MSI Katana 15 B13VEK RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI Katana 15 B13VEK RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI Katana 15 B13VEK RAM Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the existing RAM memory slot flap and gently pull apart the clamps holding the RAM in place.
    • Once the clamps have been pulled apart, remove the existing faulty RAM and set aside from the exposed laptop.
  5. MSI Katana 15 B13VEK RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI Katana 15 B13VEK RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the new RAM stick with the label facing down and the colored side going into the crease of the flap.
  6. MSI Katana 15 B13VEK RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Do steps 4-1 in reverse to put the laptop back together.
    • Test the new RAM stick by turning on the computer and going to task manager. Then click performance on the left-hand option menu. Check to see if the memory usage is about 16 GB.
    • If the memory does not say around 16 GB, restart the guide using the other RAM slot.
To reassemble your device, follow these instructions in reverse order. If there is no improvement in the laptop's memory, restart the process, exchanging the other memory stick.
Isaac K
crwdns2935283:010/01/24crwdne2935283:0
154 crwdns2915208:0crwdne2915208:0
University of Wisconsin Eau Claire, Team 1-1, Cameron Fall 2024 crwdns2935289:0University of Wisconsin Eau Claire, Team 1-1, Cameron Fall 2024crwdne2935289:0
UWEC-CAMERON-F24S1G1
crwdns2936753:030crwdne2936753:0 84
crwdns2942667:0crwdne2942667:0 645
