MSI GS66 Stealth 11UE-007 Cooling Fan Replacement
  1. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement, MSI GS66 Stealth 11UE-007 CPU Thermal Paste Replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient your laptop so that the bottom is facing up and the hinge is away from yourself.
    • Make sure to unplug device for any outlet.
  2. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Identify the nine screws around the perimeter. One screw will be under the factory seal sticker.
    • Remove eight 10mm Phillips J1 screws.
    • Remove one 7mm Philips J1 screw from the center bottom of backplate.
  3. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of the blue plastic opening tool to slip between the backplate and the body of the laptop at the hinge side.
    • Wiggle the blue plastic opening tool as you slide it around the perimeter of the backplate to separate is from the body of the laptop.
  4. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the wires from the cooling fan.
  5. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the two wires from the Wi-Fi card.
  6. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the nine 6 mm screws.
  7. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the tape connecting the fans to the fan housing.
  8. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the cooling unit like it is hinged at the back.
    • Replace thermal paste.
  9. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement, Cooling Fan: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement, Cooling Fan: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement, Cooling Fan: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the fans
Alex Robinson
crwdns2935283:009/06/23crwdne2935283:0
1,073 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 1-4, Sneed Fall 2023 crwdns2935289:0University of Memphis, Team 1-4, Sneed Fall 2023crwdne2935289:0
UM-SNEED-F23S1G4
Has anyone found a solution to this issue yet, that doesn't require micro soldering`````````````Jorge Rodriguez.
Rachel Kelley - crwdns2934203:0crwdne2934203:0
Please correct order of pictures. Description is correct but you put wrong pictures in spots. WiFi adapter isn't tape holding the heatsink assembly down.
John Banks - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 117
crwdns2942667:0crwdne2942667:0 1,974
