MSI GS65 Stealth Thin 8RE RAM Replacement
  1. MSI GS65 Stealth Thin 8RE RAM Replacement, RAM: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GS65 Stealth Thin 8RE RAM Replacement, RAM: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the fifteen black 6.0 mm Phillips #00 screws from the back cover.
    • Carefully remove the back cover.
    • It may be easier to remove the back cover by starting at the ethernet port and running something thin along the sides until the panel pops off.
    • When reassembling the back cover, it should "click" into place.
  2. MSI GS65 Stealth Thin 8RE RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GS65 Stealth Thin 8RE RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GS65 Stealth Thin 8RE RAM Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three silver 4.0 mm Phillips #00 battery screws.
    • Separate the red wire running on top of the battery from the battery.
    • Lift the battery out slightly, then carefully wiggle and pull the battery connector cable out.
    • Be sure not to pull excessively on the battery when it is still connected to the motherboard.
  3. MSI GS65 Stealth Thin 8RE RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GS65 Stealth Thin 8RE RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GS65 Stealth Thin 8RE RAM Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently unclasp and unplug the four connectors by first lifting the black locking bars of the ZIF connectors.
    • The black locking tables can be lifted by using something small such as a fingernail.
    • There may be black tape covering the ribbon cables that need to be removed.
    • Be gentle while dealing with ribbon connectors since if damaged will cause malfunction.
    • When reassembling, make sure that each ribbon connector is completely inserted before lowering the black tab.
  4. MSI GS65 Stealth Thin 8RE RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GS65 Stealth Thin 8RE RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GS65 Stealth Thin 8RE RAM Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the single 4 mm Phillips #00 screw securing the Wi-Fi card.
    • Remove the Wi-Fi card and the cable located next to it.
    • Be careful to not unplug the two wires next to the screw.
    • There will be a yellow tape covering the WiFi card that will need to be removed.
    • Make sure to keep the yellow tape to reapply on the Wi-Fi card when reassembling.
  5. MSI GS65 Stealth Thin 8RE RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GS65 Stealth Thin 8RE RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GS65 Stealth Thin 8RE RAM Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the last two ZIF ribbon connectors.
    • Slowly unpeel the black ribbon connector from the fan.
    • When reassembling, make sure to adhere the black ribbon to the motherboard in a way that does not cover the fan.
  6. MSI GS65 Stealth Thin 8RE RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GS65 Stealth Thin 8RE RAM Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GS65 Stealth Thin 8RE RAM Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the two black 6 mm Phillips #00 screws below each fan.
    • Slightly lift the motherboard.
    • While the motherboard is lifted, thread the Wi-Fi card through the hole as shown.
    • There may be a piece of yellow tape holding the WiFi card wires down that needs to be removed.
  7. MSI GS65 Stealth Thin 8RE RAM Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GS65 Stealth Thin 8RE RAM Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Double-check that everything connected to the motherboard as shown in the previous steps has been removed.
    • Carefully remove the motherboard and flip it over.
  8. MSI GS65 Stealth Thin 8RE RAM Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GS65 Stealth Thin 8RE RAM Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GS65 Stealth Thin 8RE RAM Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the RAM.
    • Carefully pull apart the silver arms holding the RAM down, and the RAM should pop up.
    • Pull the RAM out.
    • When inserting the new RAM, it will snap into place.
Annie Lin
crwdns2935283:008/22/22crwdne2935283:0
265 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 3-32, Briggs Fall 2022 crwdns2935289:0CSU Los Angeles, Team 3-32, Briggs Fall 2022crwdne2935289:0
CSULA-BRIGGS-F22S3G32
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 2,342
