MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement
  1. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement, Motherboard fans: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement, Motherboard fans: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement, Motherboard fans: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #0 driver to remove the 15 screws that hold the bottom cover:
    • Eleven 2.5 mm length screws
    • Four 5 mm length screws
    • Remove the bottom cover.
  2. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the battery.
    • Locate the battery plug and unplug it carefully
  3. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the Hard drive
    • Unplug it gently by lifting it up to unlock the black cover that connects it to the motherboard
    • Be careful not to break the black cover because it can be broken easily
    • Unplug the hard drive
  4. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • unplug this wire carefully
    • Unplug the brown wire located next to the previous wire. Unplug it gently by lifting it up to unlock the black cover that connects it to the motherboard
  5. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • unplug the selected wire. Unplug it gently by lifting it up to unlock the black cover that connects it to the motherboard
  6. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • unplug the brown selected wire. Unplug it gently by lifting it up to unlock the black cover that connects it to the motherboard
  7. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  8. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the selected wire and unplug it carefully
  9. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • unplug the selected wires
    • Unplug it gently without causing damage to the wire
  10. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • unplug the selected white wire. Unplug it gently by lifting it up to unlock the black cover that connects it to the motherboard
  11. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  12. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • remove the selected 2.5 mm screws by PH0 Bit screwdriver
    • Gently unplug the electronic chip
  13. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 2.5mm screws with a PH0 bit.
  14. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After you remove all the connected wires and unscrew all the screws that holds the motherboard to the laptop, take the motherboard out as shown in the picture.
    • Make sure it is completely diconnected from all wires and screws
  15. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the eight 2.5mm screws with a PH0 bit.
    I can't get 4/8 out, they are stuck tight and stripped.
    Tried heating the screws to break the bonds, nothing budges still.
    Anyone have luck trying anything else?
    David G - crwdns2934203:0crwdne2934203:0
  16. MSI GS60 6QE GHOST PRO 4K Motherboard fans Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After you unscrew all the screws, take the fan off to replace it.
Mafdy Wahib
crwdns2935283:009/28/17crwdne2935283:0
369 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G4, Nance Fall 2017 crwdns2935289:0USF Tampa, Team S1-G4, Nance Fall 2017crwdne2935289:0
USFT-NANCE-F17S1G4
crwdns2947412:07crwdne2947412:0
Hi, I just went through this disassembly (which is mostly great, thank you Mafdy) to replace the fans, and I wanted to point out a couple of clarifications:
Most importantly! It is NOT necessary to remove the fan/heatsink assembly from the motherboard to remove and replace the fans! Instead of proceeding with steps 15 and 16, look for tiny philips screws on the black side of the heatsink assembly which fasten each fan - 3 for one fan, 4 for the other. These are accessible once the motherboard is free from the case.
Steps 15 and 16 cause you to break the thermal compound seal on the CPU and GPU, and then proper re-assembly would mean cleaning off the old compound and correctly applying new compound before re-attaching the heatsink assembly - an unnecessary hassle just to replace the fans.
Secondly, be aware that, during steps 13-14, there are a number of additional screws and connectors that are not mentioned, that need to be removed in order to release the motherboard from the laptop housing.
Happy Fixing!
Knight9990 - crwdns2934203:0crwdne2934203:0
fans in the final section combined with copper pipe. Can they be separated? I'm having trouble finding a fan. Where can I buy new fans.
Çağlar Gökçe - crwdns2934203:0crwdne2934203:0
I have replaced both fans on gs60 today, and the instructions worked like charm! Steps 14-16 were unnecessary! Thx!
Konstantin Izmailov - crwdns2934203:0crwdne2934203:0
Just in case anyone else needs to replace the one of the fans on this laptop, I avoided having to disassemble the whole motherboard out of the laptop by using a pair of pliers to break all the plastic housinging holding the fan in place and physically ripping the fan out. I had to do this due to bearing failure on the fan.
If your fan is grinding (but still going) anecdotally, you can get slightly more life out of it by forcing in wet lubricant, but this is more of a bandaid solution.
Also if you do go through the effort of ripping out your entire heatsink and motherboard, you might as well reapply some high end thermal compound like thermal grizzly kryonaut.
Bennett Yeo - crwdns2934203:0crwdne2934203:0
Can i replace one of the fans and keep the other one or i have to replace the two of them at once because they are connected with a heatsink .
I mean, is it ez to replace just one of them and keep the other?
Ahmed Amer - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 6,741
