MSI GP62MVR 6RF Leopard Pro Motherboard Replacement
  1. MSI GP62MVR 6RF Leopard Pro Motherboard Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GP62MVR 6RF Leopard Pro Motherboard Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the laptop upside down.
    • Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
  2. MSI GP62MVR 6RF Leopard Pro Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GP62MVR 6RF Leopard Pro Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Jimmy tool to evenly pry loose the bottom cover.
    • Ensure that all sides are detached from the plastic hinging before attempting to remove the bottom cover.
  3. MSI GP62MVR 6RF Leopard Pro Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover.
    • Touching circuitry could damage components or result in personal shock; it is recommended that you now wear latex gloves to prevent both issues.
  4. MSI GP62MVR 6RF Leopard Pro Motherboard Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GP62MVR 6RF Leopard Pro Motherboard Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GP62MVR 6RF Leopard Pro Motherboard Replacement, Battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #0 Screwdriver, remove the single 5.5 mm screw fastening the battery to the body of the computer.
    • Remove the battery from the device.
  5. MSI GP62MVR 6RF Leopard Pro Motherboard Replacement, Speakers: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reorient the computer, if necessary, with a 180 degree turn so that the speakers face you.
  6. MSI GP62MVR 6RF Leopard Pro Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the front panel near the right speaker, there is a connection from the motherboard to the speakers.
    • Detach the white and black wiring from the clip.
  7. MSI GP62MVR 6RF Leopard Pro Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel back the electrical tape holding the speaker wire in place.
    • Remove the speakers from the front panel, pulling upward.
    • Note that the screws holding the two speakers down were already removed during the bottom cover removal.
  8. MSI GP62MVR 6RF Leopard Pro Motherboard Replacement, Heatsink: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GP62MVR 6RF Leopard Pro Motherboard Replacement, Heatsink: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GP62MVR 6RF Leopard Pro Motherboard Replacement, Heatsink: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove twelve 4.5 mm screws fastening the heat sink to the motherboard.
    • Unclip the red, blue, and black intertwined wire gently from the left side of the motherboard.
    • Detach the black and red wire from the right side of the motherboard, as well as peel away the black tape connecting the large black wire to the motherboard.
  9. MSI GP62MVR 6RF Leopard Pro Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the heatsink from the device.
  10. MSI GP62MVR 6RF Leopard Pro Motherboard Replacement, USB Port: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GP62MVR 6RF Leopard Pro Motherboard Replacement, USB Port: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • At the middle-top right of the motherboard, there is a ribbon wire connection to the USB port.
    • Detach the white and blue motherboard ribbon from the USB port.
  11. MSI GP62MVR 6RF Leopard Pro Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert wisdom here.
  12. MSI GP62MVR 6RF Leopard Pro Motherboard Replacement, Motherboard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • At the top right of the motherboard, there is a wired connection to the charging port.
    • Disconnect the grey charger wire from its clip on the motherboard.
  13. MSI GP62MVR 6RF Leopard Pro Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GP62MVR 6RF Leopard Pro Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The final two connections are located one the underside of the motherboard.
    • Detach the small orange and bid grey ribbons from under the motherboard, by lifting the motherboard gently from the front.
  14. MSI GP62MVR 6RF Leopard Pro Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift away the motherboard, directly upward.
Nicholas Johnson
crwdns2935283:002/18/21crwdne2935283:0
328 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S2-G18, Eggleston Spring 2021 crwdns2935289:0The Citadel Military College of South Carolina, Team S2-G18, Eggleston Spring 2021crwdne2935289:0
CMCSC-EGGLESTON-S21S2G18
crwdns2942667:0crwdne2942667:0 1,085
