Is your MSI GP60 2PE Leopard not turning on or not charging properly? Here's a guide to replace the battery. No tools are needed to replace the MSI GP60 2PE Leopard battery.
Flip MSI GP60 2PE Leopard, so that the back is facing up.
Find the unlock tab located on the upper right side of the device, then slide it to the right.
Slide and hold the release tab on the left side of the battery, so that you can remove the battery.
While holding the release tab, remove the battery slowly.
