Looking to replace your fan? This guide will help you do so with only a couple steps.
Flip the device over so the back is facing up.
Remove the four 5mm screws from the back of the device using a Phillips #00 screwdriver.
Once all four screws are removed, lift the back off.
Remove the three 5 mm screws from the fan with a Phillips #00 screwdriver.
Pull the wire on the bottom left of the fan out of the socket.
