A step by step guide to show you how to replace the RAM in this laptop, and install new ones. Please make sure to remove the battery before accessing the components in the back.
With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
Slide the optical drive out of the laptop.
Good day sir pls am urgently look for the complete cd rom for this laptop msi 1791. Please if u can get some for me text me on 7186034112
Or send me and email rauff191@gmail.com
Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
Using your fingers, gently loosen the edges of all four sides of the back cover.
Gently pull off the back cover.
Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
When you open the back cover, the RAM will be located as shown in the picture.
Press the hinges on the sides of the RAM chip as shown in the picture, in order to unlock it.
Carefully, slide it out at a 45 degree angle.
Similarly, press on the hinges on the sides of the other RAM chip, in order to unlock it.
crwdns2917034:0crwdne2917034:0
Can you put more ram in this laptop like 32gb?
Can you put another ssd?
