MSI GE72 6QF Apache Pro Fan Replacement
    1. MSI GE72 6QF Apache Pro Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GE72 6QF Apache Pro Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Make sure the laptop is off and unplugged (not charging).
      • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
    2. MSI GE72 6QF Apache Pro Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the optical drive out of the laptop.
    3. MSI GE72 6QF Apache Pro Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
    4. MSI GE72 6QF Apache Pro Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GE72 6QF Apache Pro Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using your fingers, gently loosen the edges of all four sides of the back cover.
      • Gently pull off the back cover.
    5. MSI GE72 6QF Apache Pro Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GE72 6QF Apache Pro Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
    6. MSI GE72 6QF Apache Pro Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GE72 6QF Apache Pro Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
    1. MSI GE72 6QF Apache Pro Fan Replacement, Fan: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GE72 6QF Apache Pro Fan Replacement, Fan: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GE72 6QF Apache Pro Fan Replacement, Fan: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • If you are replacing only the keyboard, you can skip to step 18, and then skip the WiFi adapter removal step. The CPU fan, m.2 SSD, RAM and WiFi adapter (marked in green) will all come off with the main board, giving you access to the keyboard.
      • Use a Phillips #1 screwdriver to remove the ten 5.5mm screws.
      • Remove the last two 5.5mm Phillips #1 screws, and remove the washers around them.
    2. MSI GE72 6QF Apache Pro Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GE72 6QF Apache Pro Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GE72 6QF Apache Pro Fan Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unplug both of the fan power cords from the laptop using a spudger.
    3. MSI GE72 6QF Apache Pro Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GE72 6QF Apache Pro Fan Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Continue to use the spudger to carefully separate the wires of the power cord from the laptop.
    4. MSI GE72 6QF Apache Pro Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GE72 6QF Apache Pro Fan Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Fully remove the fans from the rest of the laptop.
    5. MSI GE72 6QF Apache Pro Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GE72 6QF Apache Pro Fan Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GE72 6QF Apache Pro Fan Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using a Phillips #00 screwdriver, remove the six 5mm screws.
      • Separate the fans from the silver fan covers.
crwdns2935229:020crwdne2935229:0
Tanmay Kumar
crwdns2935283:004/17/17crwdne2935283:0
461 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S14-G4, Banghart Spring 2017 crwdns2935289:0Cal Poly, Team S14-G4, Banghart Spring 2017crwdne2935289:0
CPSU-BANGHART-S17S14G4
crwdns2935297:048crwdne2935297:0
crwdns2947412:09crwdne2947412:0
I can't get the back case off the last bit of it is held on pretty tight. All the screws are out so how do I loosen it?
Aaron Carlston - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where do you buy the replacement fans
customgirl - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I need a link to buy the actual fan itself if you wouldn’t mind I’d greatly appreciate it
dylan davis - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
EDIT: The only place I could actually find the fans were on walmart so Ill post the link here -> https://www.walmart.com/search/?query=ms... (I personally bought the blue one that was first I should get it by next friday and Ill try and remember to post if it works or not)
crwdns2936753:030crwdne2936753:0 172
crwdns2942667:0crwdne2942667:0 26,956
