MSI GE62 6QF Apache Pro Hard Drive Replacement
  1. MSI GE62 6QF Apache Pro Hard Drive Replacement, Optical Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the 5mm screw securing the optical drive to the bottom case.
  2. MSI GE62 6QF Apache Pro Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide Optical Drive out of the computer.
  3. MSI GE62 6QF Apache Pro Hard Drive Replacement, Bottom Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the fourteen 5mm screws on the back of the laptop.
    • One of these screws is hidden under a sticker.
  4. MSI GE62 6QF Apache Pro Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GE62 6QF Apache Pro Hard Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GE62 6QF Apache Pro Hard Drive Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three PH #0 2mm screws that were hidden underneath the optical drive.
  5. MSI GE62 6QF Apache Pro Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GE62 6QF Apache Pro Hard Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool to run along the seam of the case where the upper and bottom case meet.
    • Pry the bottom case and remove from the upper part.
  6. MSI GE62 6QF Apache Pro Hard Drive Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GE62 6QF Apache Pro Hard Drive Replacement, Battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GE62 6QF Apache Pro Hard Drive Replacement, Battery: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the single PH #0 5mm screw holding the battery pack in place.
    • Remove the battery by sliding it away from the computer.
  7. MSI GE62 6QF Apache Pro Hard Drive Replacement, Hard Drive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GE62 6QF Apache Pro Hard Drive Replacement, Hard Drive: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GE62 6QF Apache Pro Hard Drive Replacement, Hard Drive: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the two black PH #0 2mm screws holding the lower part the hard drive plate
    • Unscrew the two PH #0 4mm screws holding the upper part of the hard drive plate
  8. MSI GE62 6QF Apache Pro Hard Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GE62 6QF Apache Pro Hard Drive Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the hard drive by gently lifting up and pulling the drive out of the connection slot
crwdns2935229:05crwdne2935229:0
Justice Owens
crwdns2935283:009/26/17crwdne2935283:0
604 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G3, Passmore Fall 2017 crwdns2935289:0USF Tampa, Team S2-G3, Passmore Fall 2017crwdne2935289:0
USFT-PASSMORE-F17S2G3
Saved my life, would have had no idea what to do without these instructions and would probably have broke something. My new 2tb ssd is working fine
Simon Porter - crwdns2934203:0crwdne2934203:0
Upgraded the Memory to 32GB and the HDD to a 1TB SATA SSD.
Prabodha Elangasinha - crwdns2934203:0crwdne2934203:0
Only issue I ran into was one of the optical drive screws was frozen in, stripped hard, and I had to fall back on Moodys to break it loose. Once done, everything else was cake.
Chuck Brewer - crwdns2934203:0crwdne2934203:0
My ssd is working fine and the hdd has gone bad on mine... have not even opened mine yet but looking at the pics I wonder where the second drive is located?
Eric Jimenez - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 8,756
