Use this guide to remove the bottom case of the device.
Use a Phillips screwdriver to remove the 5mm screw securing the optical drive to the bottom case.
Slide Optical Drive out of the computer.
Use a Phillips screwdriver to remove the fourteen 5mm screws on the back of the laptop.
Remove the three PH #0 2mm screws that were hidden underneath the optical drive.
Use an opening tool to run along the seam of the case where the upper and bottom case meet.
Pry the bottom case and remove from the upper part.
