In this guide we have a MSI Force GC30 V2, model number/name is MSI Force GC30 V2 and we are disassembling the back cover plate of the controller. This will also be the first step to all other replacement guides.
Puncture the sticker where indicated using a screwdriver, then remove the 9.1 mm-long Phillips screw.
Remove the six 9.2 mm-long Phillips #0 screws.
Insert an opening pick in the gap between the front and rear case.
Slide the pick around the perimeter of the controller while prying until it fully releases.
