MSI Force GC30 V2 ABXY Buttons Replacement
  1. MSI Force GC30 V2 ABXY Buttons Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Puncture the sticker where indicated using a screwdriver, then remove the 9.1 mm-long Phillips screw.
    • Remove the six 9.2 mm-long Phillips #0 screws.
  2. MSI Force GC30 V2 ABXY Buttons Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI Force GC30 V2 ABXY Buttons Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI Force GC30 V2 ABXY Buttons Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick in the gap between the front and rear case.
    • Slide the pick around the perimeter of the controller while prying until it fully releases.
  3. MSI Force GC30 V2 ABXY Buttons Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to grip the white battery connector.
    • Pull the battery connector directly out of its port.
    • Do not pull on the wires.
  4. MSI Force GC30 V2 ABXY Buttons Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery is secured to the motherboard with a mild adhesive. If necessary, apply a small amount of high-concentration isopropyl alcohol beneath the battery to loosen the adhesive.
    • Pry carefully around the battery until it fully releases.
    • Take care not to puncture or bend the battery.
    • Remove the battery.
  5. MSI Force GC30 V2 ABXY Buttons Replacement, Vibration Motor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI Force GC30 V2 ABXY Buttons Replacement, Vibration Motor: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI Force GC30 V2 ABXY Buttons Replacement, Vibration Motor: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use blunt tweezers to disconnect both of the vibration motor connectors from the motherboard.
    • Grip the white connectors, not the wires.
    • Carefully remove both the right and left vibration motors from their housing.
  6. MSI Force GC30 V2 ABXY Buttons Replacement, ABXY Buttons: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI Force GC30 V2 ABXY Buttons Replacement, ABXY Buttons: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 7.1 mm-long Phillips #0 screw.
    • Remove the 7 mm-long Phillips #0 screw.
  7. MSI Force GC30 V2 ABXY Buttons Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI Force GC30 V2 ABXY Buttons Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the left/right bumper assembly.
  8. MSI Force GC30 V2 ABXY Buttons Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI Force GC30 V2 ABXY Buttons Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the motherboard out of its casing and remove it.
  9. MSI Force GC30 V2 ABXY Buttons Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI Force GC30 V2 ABXY Buttons Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ABXY button either by pulling them out or turning the controller the other side and letting the buttons fall out.
  10. MSI Force GC30 V2 ABXY Buttons Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI Force GC30 V2 ABXY Buttons Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI Force GC30 V2 ABXY Buttons Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ABXY button membrane by carefully lifting it off the motherboard.
Matthew Harber
crwdns2935283:002/26/24crwdne2935283:0
503 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 1-4, Sneed Spring 2024 crwdns2935289:0University of Memphis, Team 1-4, Sneed Spring 2024crwdne2935289:0
UM-SNEED-S24S1G4
crwdns2942667:0crwdne2942667:0 342
