MNT Pocket Reform Bottom Cover Replacement
  1. MNT Pocket Reform Bottom Cover Replacement, Shut down the laptop: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MNT Pocket Reform Bottom Cover Replacement, Shut down the laptop: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MNT Pocket Reform Bottom Cover Replacement, Shut down the laptop: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you've installed an operating system, follow the appropriate steps to safely shut down the laptop.
    • If you've not yet installed an operating system, or the laptop is not responsive, you can shut it down with these steps:
    • Turn on the OLED screen by pressing the Hyper key (diagonal arrow) and Enter at the same time.
    • Use the arrow keys to select Power Off on the OLED screen.
    • Press Enter to shut down the laptop.
    • Disconnect all cables from the laptop.
  2. MNT Pocket Reform Bottom Cover Replacement, Turn off the standby power: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MNT Pocket Reform Bottom Cover Replacement, Turn off the standby power: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a small tool, like a SIM eject tool or a bent paperclip, to turn off the standby power switch by sliding the switch away from the headset jack.
    • The standby power switch is located in a small recess on the same side as the headset jack.
  3. MNT Pocket Reform Bottom Cover Replacement, Remove the bottom cover screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MNT Pocket Reform Bottom Cover Replacement, Remove the bottom cover screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the laptop on your work surface so the bottom cover, with the regulatory info box, is facing up.
    • Use a Phillips screwdriver to remove the six 4.8 mm‑long screws securing the bottom cover.
  4. MNT Pocket Reform Bottom Cover Replacement, Remove the bottom cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MNT Pocket Reform Bottom Cover Replacement, Remove the bottom cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MNT Pocket Reform Bottom Cover Replacement, Remove the bottom cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The bottom cover is made of printed circuit board (PCB) material. Press gently but firmly near an edge when applying the suction handle to avoid breaking the cover.
    • Apply a suction handle to the bottom cover.
    • Use the suction handle to lift the bottom cover off of the laptop.
    • Alternatively, you can use a thin prying tool to lift the cover, or tilt the laptop until the cover falls out.
    • During reassembly, place the bottom cover on the laptop so the info box is opposite the hinges.
Spencer Pennington
crwdns2935283:009/09/23crwdne2935283:0
19.435 crwdns2915208:0crwdne2915208:0
crwdns2935297:0114crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:022.008crwdne2935297:0
crwdns2942667:0crwdne2942667:0 104
