Make sure the door lock and handle are in good working order and not bent or loose
Check the opt cords to make sure they aren’t broken or crimped
Make sure all the opt box lights that are supposed to be on are on.
Clean belts on top and on the back of the dispenser.
Test dispense the coin hoppers and the cash dispenser
Check the coin hoppers to make sure nothing is in it other than coins (like rubber bands or something that was dropped in it)
Check the printer for paper and put in more if it's needed
Open and blow out the printer to remove any loose paper
Run a cleaning strip through the BV
Check for coins on the BV board.
Put a board protector on if it’s missing and you have one available
Clean the touch screen
Check to see if the door lights are on and working
