Lorex MC6950 Motor Replacement
  1. Lorex MC6950 Motor Replacement, Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lorex MC6950 Motor Replacement, Motor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the motor, you must begin by removing the three screw caps and the 15mm JIS 0 screws associated with them located on the plastic containment shell that the camera is in.
  2. Lorex MC6950 Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lorex MC6950 Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Next, the camera must be removed. A metal spudger will be useful to pry this out as it is sealed inside the outer containment shell.
    • Once the camera is removed, remove the wires from the outer containment shell.
    • Be careful. The metal spudger could damage the camera if not handled with care.
  3. Lorex MC6950 Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lorex MC6950 Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the camera in hand, the circuit board must be separated from the LED containment shell. There is a 5mm JIS 0 screw at every corner of the circuit board.
    • The wires attaching the circuit board to the shell should be removed as well.
  4. Lorex MC6950 Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now the motor housing must be removed from the circuit board. There are three 5mm JIS 0 screws located on the lens side of the circuit board that need to be removed.
  5. Lorex MC6950 Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lorex MC6950 Motor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lorex MC6950 Motor Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The motor will be sealed in the housing. It can be removed by using a metal spudger to cut the seal. Any common sealant can be used on the replacement motor.
    • The motor housing will need to be soldered back onto the circuit board after the new motor is placed. The wires should come from the circuit board and connect to the motor housing on the opposite of the lens side of the circuit board.
Elijah Conlin
crwdns2935283:011/07/17crwdne2935283:0
379 crwdns2915208:0crwdne2915208:0
IUPUI, Team S2-G2, Harley Fall 2017 crwdns2935289:0IUPUI, Team S2-G2, Harley Fall 2017crwdne2935289:0
IUPUI-HARLEY-F17S2G2
crwdns2942667:0crwdne2942667:0 190
