If your Logitech K360 keyboard has unresponsive keys or erratic behavior, the internal printed circuit board (PCB) may need replacing. Use our guide so you can replace it safely!
With your thumbs on both sides of the battery tab, push upwards.
Remove the cover exposing the batteries.
Remove the keyboard cover.
Remove the screws using a Phillips #0 screwdriver.
Remove the top half of the keyboard carefully.
Unscrew the two 2.0 mm silver screws using a Phillips #0 screwdriver.
Unscrew the two 2.0 mm silver screws on either side of the printed circuit board (PCB) using a Phillips #0 screwdriver.
Lift the entire printed circuit board (PCB) out of the panel.
