Logitech Webcam Pro 9000 USB Cable Replacement
  1. Logitech Webcam Pro 9000 USB Cable Replacement, Front and Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Webcam Pro 9000 USB Cable Replacement, Front and Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Logitech Webcam Pro 9000 USB Cable Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Webcam Pro 9000 USB Cable Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  3. Logitech Webcam Pro 9000 USB Cable Replacement, USB Connection: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Webcam Pro 9000 USB Cable Replacement, USB Connection: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to grasp the white wire connector on the back of the motherboard.
    • Wiggle the connector back and forth to remove it from the socket.
  4. Logitech Webcam Pro 9000 USB Cable Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Webcam Pro 9000 USB Cable Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder the joint on the front of the motherboard to completely detach the USB cable.
    • Follow this link to learn how to properly solder and desolder your parts.
  5. Logitech Webcam Pro 9000 USB Cable Replacement, USB Cable: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Webcam Pro 9000 USB Cable Replacement, USB Cable: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Webcam Pro 9000 USB Cable Replacement, USB Cable: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wedge the pointy end of the spudger between the sliver E-ring and USB attachment base to extract the E-ring and release the USB cable.
  6. Logitech Webcam Pro 9000 USB Cable Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Webcam Pro 9000 USB Cable Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Feed the end of the disconnected USB cable through the back cover.
    sir where i baught logitech pro 9000 cable
    Shiva Ji Sachan - crwdns2934203:0crwdne2934203:0
Cory Davis
crwdns2935283:004/14/13crwdne2935283:0
236 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-34, Amido Spring 2013 crwdns2935289:0Cal Poly, Team 12-34, Amido Spring 2013crwdne2935289:0
CPSU-AMIDO-S13S12G34
Ich habe auch. ich braucht neu Kabel für C910 aber wo finden?
wohlgemuth1981 - crwdns2934203:0crwdne2934203:0
In hindsight, I wish I had just ordered a new camera. It is more difficult than these instructions make it look. I found a replacement cable on Amazon. Disassembly and removal of the old cable was easy. Soldering of the single wire on the new cable was difficult. I'm not as steady as I used to be, and the tiny cable and small board made it a difficult task. Once I finished the soldering, reassembly was easy except for the cable clip. Once done and I plugged it in, the camera would not work--USB device not recognized. I don't know whether the cable was incorrect or if I messed something up during the soldering. I finally trashed the old camera and ordered a new Logitech c920s. Wasted $10 on the failed cable and spent $70 on the new camera.
If you are unsure, it might be worth spending the money to upgrade instead of wasting time and money on a failed replacement cable like I did.
Ron Anderson - crwdns2934203:0crwdne2934203:0
As an update to the above-- My repair failed because I had ordered the wrong cable.
crwdns2942667:0crwdne2942667:0 6,897
