Logitech UE MegaBoom Power Button Replacement
  1. Logitech UE MegaBoom Power Button Replacement, Outer Mesh: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE MegaBoom Power Button Replacement, Outer Mesh: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE MegaBoom Power Button Replacement, Outer Mesh: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the ends of the speaker.
    • Put a plastic opening tool in-between the rubber end and the mesh.
    • Apply a upward force in order to pry open the end.
    • Apply this procedure to the other side as well.
    • Will take force.
    • Using metal tools may permanently mar your device.
    Pry all the way around with the tool as there are “clips” that hold the cap in place all around beneath the cap. Avoid trying to “pull the lid open” from the opening of a half opened lid.
    Jamin Hu - crwdns2934203:0crwdne2934203:0
    Stop! Before you proceed, notice the comments at the end of the guide. You don't have to take apart both sides or remove the mesh fabric. Remove just the bottom cap (with the aux/charge plug).
    Then carefully remove the glue securing the circuit board on the sides and gently pull the board out to reveal the battery under it.
    Caleb Kelsay - crwdns2934203:0crwdne2934203:0
    FWIW I had no luck opening these caps with the tools I bought on iFixit (plastic pry bar, metal Jimmy). I had a lot more luck using the flat edge of a butter knife! (it still took lots of work on my UE Megaboom 3)
    Travis Taylor - crwdns2934203:0crwdne2934203:0
    My megaboom berttrey doesn't charge it becomes like power defending
    Lawrence Memsong - crwdns2934203:0crwdne2934203:0
  2. Logitech UE MegaBoom Power Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE MegaBoom Power Button Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE MegaBoom Power Button Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
    • You will hear clicks as it pries up, don't worry.
    • Remove all the rubber you pried off.
    Die Deckelseite mit den Eingängen USB und Aux geht deutlich leichter auf und reicht auch!!!
    anschlie0end seitlich den Gummistreifen lockern, dass der Deckel zurück geklappt werden kann.
    Dann muss die ca 2cm starke Deckelplatte mit dem kompletten Umfang (ist auf die Box aufgesteckt ab.
    Hierzu das Gewebe nur an dieser Seite aus der Halterung fummeln, dann müsste die Abdeckung schon herausgehen, zur Not das Gewebe an der Längsseite lösen.
    Resümée: Die Anleitung hier zeigt viel zu viele Schritte, die entscheidenden fehlen aber und dann fängt die Anleitung auch noch am falschen Ende an!
    Daniel - crwdns2934203:0crwdne2934203:0
  3. Logitech UE MegaBoom Power Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech UE MegaBoom Power Button Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
    • Work the plastic retainer out of the channel all the way around the speaker.
    • Be gentle, it is easy to damage the fabric.
    • Repeat for other side.
    No need to remove fabric or remove both sides.
    Gavin McGlynn - crwdns2934203:0crwdne2934203:0
    I suppose, if you want to swap the external fabric (for what this guide is basically), you have to remove it first ;-)
    BenZ78 -
    what do you do once fabric removed. can't see how to expose battery
    jonathan scott - crwdns2934203:0crwdne2934203:0
    This guide is how to swap the fabric only. To change the battery you can use this guide.
    BenZ78 -
  4. Logitech UE MegaBoom Power Button Replacement, Power Button: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech UE MegaBoom Power Button Replacement, Power Button: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the end of the speaker which contains the power button.
    • The circuit board which contains the power button should be visible.
    • Grasp the outer rim of this end cap and pull in an upward motion.
    • This might require some force.
  5. Logitech UE MegaBoom Power Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a opening tool between the circuit board and one of the black clips which is holding the board in place.
    • Using the opening tool pry up on the clip allowing the board to be freed. Pry up on the second clip to fully release the board.
    • Using your fingers lift the board out of place.
Oscar Ambriz
crwdns2935283:009/27/17crwdne2935283:0
965 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S9-G2, Banghart Fall 2017 crwdns2935289:0Cal Poly, Team S9-G2, Banghart Fall 2017crwdne2935289:0
CPSU-BANGHART-F17S9G2
crwdns2935297:017crwdne2935297:0
Will it still be waterproof after repairing?
TechBrush - crwdns2934203:0crwdne2934203:0
that would be a negative unless you really know what you are doing and can waterproof it
Justin Doubikin -
nice piece. i was able to follow the guide and got it right taking out the board. please where can one purchase the power button board. thanks
tony - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 4,701
