Logitech UE MegaBoom Battery Replacement
  1. Logitech UE MegaBoom Battery Replacement, Outer Mesh: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE MegaBoom Battery Replacement, Outer Mesh: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE MegaBoom Battery Replacement, Outer Mesh: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the ends of the speaker.
    • Put a plastic opening tool in-between the rubber end and the mesh.
    • Apply a upward force in order to pry open the end.
    • Apply this procedure to the other side as well.
    • Will take force.
    • Using metal tools may permanently mar your device.
  2. Logitech UE MegaBoom Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE MegaBoom Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE MegaBoom Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
    • You will hear clicks as it pries up, don't worry.
    • Remove all the rubber you pried off.
  3. Logitech UE MegaBoom Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech UE MegaBoom Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
    • Work the plastic retainer out of the channel all the way around the speaker.
    • Be gentle, it is easy to damage the fabric.
    • Repeat for other side.
  4. Logitech UE MegaBoom Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull on white strip to remove battery.
    • Remove inner plastic gasket on circuit board.
    • Remove 2nd plastic gasket around outer circuit board edge, under rubber gasket.
    • Gently pry circuit board up out of recess.
crwdns2935229:017crwdne2935229:0
Oscar Ambriz
crwdns2935283:009/27/17crwdne2935283:0
977 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S9-G2, Banghart Fall 2017 crwdns2935289:0Cal Poly, Team S9-G2, Banghart Fall 2017crwdne2935289:0
CPSU-BANGHART-F17S9G2
crwdns2935297:017crwdne2935297:0
crwdns2947412:024crwdne2947412:0
There is a way to take it apart without all these steps and a complete tear down.
Brian Longhurst - crwdns2934203:0crwdne2934203:0
How to ensure it’s waterproof upon reassembly?
mdeblasi - crwdns2934203:0crwdne2934203:0
This is huge overkill. Only the bottom cap and circuit board need to be removed for a battery replacement.
coryjohnson011 - crwdns2934203:0crwdne2934203:0
I agree. The battery is located on the bottom end only.
Jamin Hu -
^ the person who says that you only need to remove the one end-cap to replace the battery is correct. The process outlined in this article is more likely to damage all the fabric and other end-cap than just opening one end and gently prying it back until you can slide out the battery. FYI, the pull tab on my battery broke right off, and I had to pull it out with pliers.
sizz0p - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 24
crwdns2936753:07crwdne2936753:0 152
crwdns2936753:030crwdne2936753:0 731
crwdns2942667:0crwdne2942667:0 63,132
