Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement
  1. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Outer Mesh: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Outer Mesh: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Outer Mesh: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the ends of the speaker.
    • Put a plastic opening tool in-between the rubber end and the mesh.
    • Apply a upward force in order to pry open the end.
    • Apply this procedure to the other side as well.
    • Will take force.
    • Using metal tools may permanently mar your device.
  2. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
    • You will hear clicks as it pries up, don't worry.
    • Remove all the rubber you pried off.
  3. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
    • Work the plastic retainer out of the channel all the way around the speaker.
    • Be gentle, it is easy to damage the fabric.
    • Repeat for other side.
  4. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Auxiliary Port and micro USB Port: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Auxiliary Port and micro USB Port: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Auxiliary Port and micro USB Port: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply an upward force with your thumbs to loosen the end cap.
    • Grasp the end cap and lift up to seperate it from the base.
  5. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers or an opening tool to remove the plastic insert on the inside of the rubber seal.
    • Push up on the rectangular connector from the bottom to loosen the circuit board.
  6. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now grasp the plastic on the outside of the rubber seal and pull it out by applying an upward force.
    • Once the plastic has been removed, pull out the circuit board containing the auxiliary and USB ports.
Oscar Ambriz
crwdns2935283:009/27/17crwdne2935283:0
958 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S9-G2, Banghart Fall 2017 crwdns2935289:0Cal Poly, Team S9-G2, Banghart Fall 2017crwdne2935289:0
CPSU-BANGHART-F17S9G2
crwdns2944067:010crwdne2944067:0
How can I purchase this part being replaced thanks
Joseph Anderson - crwdns2934203:0crwdne2934203:0
where can i get that part the whole board usb aux i need to replace due to water damage
jdw vlogs - crwdns2934203:0crwdne2934203:0
I also need this part due to water damage. Where Do I order this entire motherboard at?
dersert6bunnie - crwdns2934203:0crwdne2934203:0
Hello. Did you find the spare part?
Ionut -
I don’t think you can buy the parts new. Try buying a used/broken speaker for parts that has a working part that you need.
Nick Johnston - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 89
crwdns2942667:0crwdne2942667:0 11,309
