Logitech UE Hyperboom Motherboard Replacement
    1. Logitech UE Hyperboom Motherboard Replacement, Handle: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech UE Hyperboom Motherboard Replacement, Handle: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew the two black flat-top screws that attach the handle to the speaker with your hands.
      • You may need pliers to grip the screws.
    1. Logitech UE Hyperboom Motherboard Replacement, Top Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech UE Hyperboom Motherboard Replacement, Top Panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use your hands to carefully pry the plastic cover off of the speaker.
    2. Logitech UE Hyperboom Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE Hyperboom Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE Hyperboom Motherboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a Phillips #0 screwdriver to remove the ten 11.7mm screws on the top panel.
      • Remove the top panel to access the internal components.
      • Use a metal spudger to completely disconnect the top panel.
    1. Logitech UE Hyperboom Motherboard Replacement, Speaker Drivers and Tweeters: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech UE Hyperboom Motherboard Replacement, Speaker Drivers and Tweeters: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the Jimmy to pry the fiber mesh cover away from the speaker.
      • Take the fiber mesh off of the speaker completely.
    2. Logitech UE Hyperboom Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE Hyperboom Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE Hyperboom Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the Phillips #0 screwdriver to unscrew the three 9.2mm screws around the tweeter speaker.
      • Use the Phillips #0 screwdriver to unscrew the eight 10.1mm screws around the speaker driver.
      • Use a metal spudger to pry the tweeter speaker out of the socket.
    3. Logitech UE Hyperboom Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE Hyperboom Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE Hyperboom Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a metal spudger to break the adhesive seal around the speaker driver.
      • Use your hands to push the speaker driver out of its socket.
      • A lot of force will be necessary, so it is possible the power and ground cables might disconnect from the force of dislodging the speaker driver.
      • Disconnect the power and ground cables from both the speaker driver and tweeter.
    4. Logitech UE Hyperboom Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the speaker over, and face the two other speaker driver towards you.
      • Use the Phillips #0 screwdriver to remove the three 9.2mm screws around the speaker tweeter.
      • Use the Phillips #0 screwdriver to remove the eight 10.1mm screws around the speaker driver.
    5. Logitech UE Hyperboom Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech UE Hyperboom Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a metal spudger to break the adhesive between the tweeter and the casing.
      • Disconnect the power and ground cables from the tweeter speaker to remove it completely.
    6. Logitech UE Hyperboom Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE Hyperboom Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE Hyperboom Motherboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use your hands to remove the speaker driver from its socket.
      • Disconnect the power and ground cables to remove it completely.
    1. Logitech UE Hyperboom Motherboard Replacement, Motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech UE Hyperboom Motherboard Replacement, Motherboard: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Disconnect all of the cables connected to the motherboard.
    2. Logitech UE Hyperboom Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE Hyperboom Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE Hyperboom Motherboard Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a Phillips #0 screwdriver to remove the four supporting 7.9mm screws.
      • Slide the motherboard out of the top of the speaker.
Ethan Abbott
crwdns2935283:003/10/26crwdne2935283:0
859 crwdns2915208:0crwdne2915208:0
Idaho State University, Team 1-2, Watkins Spring 2026 crwdns2935289:0Idaho State University, Team 1-2, Watkins Spring 2026crwdne2935289:0
ISU-WATKINS-S26S1G2
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 150
