Use this prerequisite guide as an initial step before accessing the internal components of the speaker.
Unscrew the two black flat-top screws that attach the handle to the speaker with your hands.
Use the Jimmy to pry off the four rubber feet on the bottom of the speaker.
Use a Phillips #0 screwdriver to remove all twelve 11.7mm screws from the bottom panel of the speaker.
Pull the panel off to access the internal components.
