Use this guide to replace the battery in a Logitech UE Hyperboom Bluetooth Speaker. The battery is what supplies power to every component of the speaker. Batteries generally are the first component to fail in a device, so it is likely that the battery is the source of an issue. If your speaker shuts down unexpectedly, refuses to power on without being plugged in, or shows extremely reduced playtime, a battery replacement might be necessary.
Before beginning this guide, be sure to power off your speaker.
Unscrew the two black flat-top screws that attach the handle to the speaker with your hands.
Use your hands to carefully pry the plastic cover off of the speaker.
Use a Phillips #0 screwdriver to remove the ten 11.7mm screws on the top panel.
Remove the top panel to access the internal components.
Use a metal spudger to completely disconnect the top panel.
Unplug the battery cord from the motherboard.
Remove the battery from the battery compartment.
