Logitech UE Boombox Speaker Replacement
  1. Logitech UE Boombox Speaker Replacement, Speaker Grille: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech UE Boombox Speaker Replacement, Speaker Grille: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a metal spudger to pry open the power button cover.
    • Once the power button cover is slightly opened, use your fingers to remove the power button cover.
  2. Logitech UE Boombox Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press firmly on the end of the latch and pull the two-wire connector away from the base to separate.
  3. Logitech UE Boombox Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Firmly press on the end of the latch and pull the four-wire connector away from the base to separate.
  4. Logitech UE Boombox Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lightly, pry up on each side of the black band connector lock using your fingertips.
    • Once unlocked, pull straight up on the connector to remove.
  5. Logitech UE Boombox Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five black 14mm Phillips #2 screws from the black plastic side panel.
    • Remove the one silver 16mm Phillips #2 screws from the black plastic side panel.
    • Remove the black plastic screw panel from the boombox.
  6. Logitech UE Boombox Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the opposite side of the device, pry open the volume rocker with a metal spudger.
    • Remove the panel with your fingers once the volume rocker is slightly opened.
  7. Logitech UE Boombox Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the one silver16 mm Phillips #2 screw from the black plastic side panel.
    • Once all screws are removed, take the screw panel out of the device to gain access to the back of the panel.
  8. Logitech UE Boombox Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly press on the end of the latch and pull the two-wire connector away from the base.
  9. Logitech UE Boombox Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull up on the aluminum boombox handle to remove.
  10. Logitech UE Boombox Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a metal spudger to pry the rubber base apart from the aluminum grille.
  11. Logitech UE Boombox Speaker Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the rubber base away from the boombox.
  12. Logitech UE Boombox Speaker Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four black 7.5mm Phillips #2 screws on each side of the device.
    • There should be a total of eight screws removed in this step.
  13. Logitech UE Boombox Speaker Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull vertically on the speaker grille to remove it from the boombox.
  14. Logitech UE Boombox Speaker Replacement, Speaker: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE Boombox Speaker Replacement, Speaker: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE Boombox Speaker Replacement, Speaker: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the fifteen 13.0 mm screws with a #0 Phillips from the side of the device containing two speakers.
    • Separate the two halves by gently pulling them apart.
    • The screws at this step are embedded deep within the device so make sure your screw driver is long.
  15. Logitech UE Boombox Speaker Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the speaker adjacent to the motherboard.
  16. Logitech UE Boombox Speaker Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  17. Logitech UE Boombox Speaker Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 7.0 mm screws with a Phillips #2.
  18. Logitech UE Boombox Speaker Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the speaker out of the device using your fingers.
  19. Logitech UE Boombox Speaker Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the lock to detach the band connector from the motherboard.
  20. Logitech UE Boombox Speaker Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove five 7.0 mm screws on the motherboard with a Phillips #2.
  21. Logitech UE Boombox Speaker Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the motherboard with your fingers.
    • Flip over to reveal the underside.
    • Motherboard will still be attached to the device.
  22. Logitech UE Boombox Speaker Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the lock of the band connector to detach it from the motherboard.
  23. Logitech UE Boombox Speaker Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Desolder all four wires connecting the speaker.
    • One red and one black wire are located on each side of speaker.
  24. Logitech UE Boombox Speaker Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove four 7.0 mm screws with a Phillips #2.
  25. Logitech UE Boombox Speaker Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech UE Boombox Speaker Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
Breean Mokede
crwdns2935283:009/15/16crwdne2935283:0
282 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team 1-1, Bruce Fall 2016 crwdns2935289:0CSU Fullerton, Team 1-1, Bruce Fall 2016crwdne2935289:0
CSUF-BRUCE-F16S1G1
Could you recommend anywhere to find the correct replacement tweeters & drivers?
Ted Glasgow - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,665
