This guide is for the Logitech UE Boom 3 - model number: S-00171. Alternative model numbers could be S-00171-A, S-00171-B, S-00171-C.
The primary objective of this guide is to provide step-by-step instructions for replacing the passive radiator of the Logitech UE BOOM 3. By following these instructions carefully, users can address issues such as poor bass performance.
The passive radiator plays a pivotal role in enhancing its bass performance without compromising its compact design. By harnessing the air pressure generated by the active drivers, the passive radiator effectively amplifies low-frequency output, resulting in deeper, more resonant bass tones.
Insert a Jimmy into the space between the body and the lid.
Wiggle the Jimmy to loosen the lid. Continue around the lid until lid comes off.
Pull or push the body of the speaker out of the casing.
Remove the metal bars from the body of the speaker using the spudger.
Carefully pull out the speaker driver from the body of the speaker.
Use a spudger to pry open the passive radiators on both sides.
