crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Logitech S120 Slim Mini Stereo Speakerscrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Logitech S120 Slim Mini Stereo Speakers Teardown, Logitech S120 Slim Mini Stereo Speakers Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desktop Computer Speakers
    • Weight: 1lb
    • Height: 6.22 in
    • Width: 2.67 in
    • Depth: 2.51 in
    • Power: 2.2W (RMS)
    • RCA and 3.5mm jack inputs
  2. Logitech S120 Slim Mini Stereo Speakers Teardown, Remove Speaker Grill: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the speaker grills using a thin, flat object such as a flathead screwdriver.
    • Insert the tool where the grill connects to the chassis just above the logitech logo.
    • Pry upwards until the grill releases
  3. Logitech S120 Slim Mini Stereo Speakers Teardown, Open the Speaker Chassis: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the flathead screwdriver in the seam between the speaker chassis.
    • Use force to jam the flathead screwdriver into the chassis.
    • Drag the screwdriver around the chassis until the two sides separate.
  4. Logitech S120 Slim Mini Stereo Speakers Teardown, Remove Internal Components: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a phillips head screwdriver, remove the screws holding the PCB, transformer, and speakers to the chassis.
    • Pull the PCB, transformer, and speakers from the chassis.
  5. Logitech S120 Slim Mini Stereo Speakers Teardown, Examine Speaker Driver: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The driver board contains several components
    • Stereo Amplifier: TEA2025B
    • 5mm LED power indicator
    • Potentiometer and on/off switch
    • Decoupling, bypass, and AC coupling capcaitors
bglidden95
crwdns2935283:002/14/14crwdne2935283:0
130 crwdns2915208:0crwdne2915208:0
I took mine apart, only the Speaker that contains the On/Off Volume— Potentiometer. That Speaker fell off my table and hit the floor landing on the Volume control knob, since then the Speakers do not work unless I insert something to keep pressure on the Volume Control’s shaft. Is it possible to obtain and replace the potentiometer/On/Off Switch…?
James L Parmenter - crwdns2934203:0crwdne2934203:0
Yeah. Same here. I was blown away of the fact that there are no trasistors. Zero. None.
There is one IC chip, SC1863. But I cant find info on it.
Actually I just want to use it as a portable usb powered guitar amp. But I cant get my head around no transistors in it. Weird, huh?
Siggy Retburns -
crwdns2936753:030crwdne2936753:0 61
crwdns2942667:0crwdne2942667:0 7,905
