Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement
  1. Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement, Inner Speaker Cones: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement, Inner Speaker Cones: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement, Inner Speaker Cones: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the plastic cover. You want to use the plastic opener and starting with corners.
    • Then insert the metal spudger in the opening and slowly move the metal spudger along all sides of the cover.
    • Caution: Metal spudger can damage the internal components of the device such as the motherboard. Make sure to use it carefully in order to avoid any unnecessary damages.
    • Make sure the metal supdger is inserted deep enough as the cover is glued to the device.
    • Carefully remove the cover as it can be very fragile
  2. Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove eight 10.5 mm Phillips #1 screws from the cover.
    • Insert a metal spurger at the corner to help loosen the cover.
    • There is still glue sticking the front cover and the back cover together.
    • Starting with corners, lift up the cover slowly and carefully.
    • Do not pull too hard when removing the cover. There are wires connecting between the battery and the circuit board.
  3. Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Identity the speaker cover, and remove four 4.5 mm Phillips #1 screws.
    • Lift up the cone. It should be removed very easily by hand.
  4. Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four 5.2mm Phillips #1 screws that are securing the circuit board.
    • Unplug the connecting wire from the circuit board. Carefully lift up the circuit board.
    • Same as step 3, remove four 4.5 mm Phillips #1 screws from the speaker cone.
junyi yang
crwdns2935283:007/11/18crwdne2935283:0
109 crwdns2915208:0crwdne2915208:0
IUPUI, Team S4-G4, Wilson Summer 2018 crwdns2935289:0IUPUI, Team S4-G4, Wilson Summer 2018crwdne2935289:0
IUPUI-WILSON-SU18S4G4
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 1,320
