Logitech Pure-Fi Anywhere 2 Battery Replacement
  1. Logitech Pure-Fi Anywhere 2 Battery Replacement, Loosening cosmetic plastic cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Pure-Fi Anywhere 2 Battery Replacement, Loosening cosmetic plastic cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To avoid damage to the outside of the casing create a first opening with a plastic opening tool.
    • Insert the metal spudger in the opening you just created.
    This process can be made a bit easier by using a hair dryer or a heat gun on its low temperature setting to warm up the front plastic. Whatever you choose to use, make sure the heat source keeps moving and heats up the entire plate evenly. When the front plate is very warm to the touch, the glue will let go more easily.
    Eric in Newton - crwdns2934203:0crwdne2934203:0
  2. Logitech Pure-Fi Anywhere 2 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Pure-Fi Anywhere 2 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now work your way along all sides, cuting through the glue with the spudger. The glue is all over so make make sure to go deep enough under the cover with the spudger.
  3. Logitech Pure-Fi Anywhere 2 Battery Replacement, Removing cosmetic cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Pure-Fi Anywhere 2 Battery Replacement, Removing cosmetic cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Pure-Fi Anywhere 2 Battery Replacement, Removing cosmetic cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the plastic cover to get access to the screws.
    • The glue will still stick when reassambling the Pure-Fi Anywhere.
  4. Logitech Pure-Fi Anywhere 2 Battery Replacement, Unscrew front cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight Phillips screws securing the front cover to the back cover.
  5. Logitech Pure-Fi Anywhere 2 Battery Replacement, Open the device: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Pure-Fi Anywhere 2 Battery Replacement, Open the device: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the front cover up away from the back cover. Do not pull them apart too far though as the battery is secured to the back cover while everything else is secured to the front cover.
    • Chances are that the wires running from the battery itself to the connector are firmly tucked behind the battery making it hard to get a grip on the connecter so just leave it connected for now.
    Not sure if authors had this but mine had some glue along the bottom edge meaning I had to use the spudger to loosen it, but don't push it too far in as you risk hitting wires or the circuit board.
    Oliver Pereira - crwdns2934203:0crwdne2934203:0
  6. Logitech Pure-Fi Anywhere 2 Battery Replacement, Remove battery cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Pure-Fi Anywhere 2 Battery Replacement, Remove battery cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Pure-Fi Anywhere 2 Battery Replacement, Remove battery cover: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two Phillips screws securing the battery cover.
    • Remove the battery cover to finaly get access to the battery.
    • Now you can get a good grip on the battery connector to disconnect it.
    • Replace with new battery!
  7. Logitech Pure-Fi Anywhere 2 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Chances are your replacement battery doesn't have foam tape taped around it. If you don't have a roll of foam tape lying around at home just gently peel off the tape from the old battery and aply it to the new battery. This will ensure that the battery will firmly be secured under the battery cover.
    Note: This process is exactly the same for the original Pure-Fi Anywhere.
crwdns2935229:018crwdne2935229:0
EricV
crwdns2935283:008/01/15crwdne2935283:0
788 crwdns2915208:0crwdne2915208:0
Excellent guide. Thanks for taking the trouble to include numerous pictures - it makes all the difference. I found separating the glue from the cover was a bit daunting but once apart the rest was easy.
Andrew - crwdns2934203:0crwdne2934203:0
FANTASTIC!!
this really helped me resurect one of my favourite Products which would have otherwise ended up in the trash!
chris - crwdns2934203:0crwdne2934203:0
Amazing bro, i was suspecting that could be the way of doing it, but was too afraid of breaking it.
rodri_opomoz - crwdns2934203:0crwdne2934203:0
Worked for me! Good guide. BTW: the speaker has amazing sound
David Lai - crwdns2934203:0crwdne2934203:0
Good guide. I did not want to spend $14.00 for a battery. I took apart an old hp laptop battery which has 6 cells in it. Checked and they were not completely dead. Removed 2 cells ( I have 2 of these iPod docks). Soldered the small control board/ harness to the “new” cells. Works. Getting a little over 4hrs played at second loudest volume. Good enough. Have 2 working units for zero cost. Just ordered a Bluetooth iPod adapter ($4.60) so I can be full wireless. Really good sound too.
Steve Solorio - crwdns2934203:0crwdne2934203:0
Genuinely excellent guide backed up with very well taken photos. 10/10. Kind thanks for the taking the time Eric. 🍻
Jisp - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 10,649
