Logitech Mouse G302 Disassembly
  1. Logitech Mouse G302 Disassembly, Open the case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Mouse G302 Disassembly, Open the case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the mouse over to gain access to the bottom.
    • Using a scalpel, pick, or similar tool, peel away the slide pads on the bottom of the mouse in order to expose the three screws.
    • Using a PH0 / Phillips #0 driver, remove the 3 screws shown in red.
    • Peel away as little of the pads as possible, in order to preserve the adhesive on their undersides.
    • Gently separate the two halves of the case. Light prying may be required.
    • For PCB removal : remove 3 PH0 screws from PCB surface. The whole PCB can be taken out for inspection and repair after the screws are removed.
  2. Logitech Mouse G302 Disassembly, Switch replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Mouse G302 Disassembly, Switch replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The switch's brand is Omron. Part number: D2FC-F-7N. Components have 3 pins leaded type (two utilized)
    • I experienced one switch working intermittently. In such case, I recommend replacing both L & R switches.
  3. Logitech Mouse G302 Disassembly, Switch information: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is helpful for finding the correct replacement or compatible replacement e.g. vendors from online store AliExpress.
    • I used this as a successful replacement: RS Components Stock No. 682-1519 microswitch. Manufacturer is Omron, manufacturer part number is D2F-F.
    I bought maybe 50 of these switches from someone in China. Same switch is used in so many rodents. When a button goes dodgy I replace it. Mostly both. I carry a compact gas iron and solder sucker when on the road and they get used often.
    John Shaw - crwdns2934203:0crwdne2934203:0
Carsten Dahl Hjarup
crwdns2935283:011/04/13crwdne2935283:0
3,081 crwdns2915208:0crwdne2915208:0
what is the name and type of switch number 3 / sw3
Yanuar Arifiyanto - crwdns2934203:0crwdne2934203:0
Did the job on my own mouse just tonight. The screws are actually Phillips #000, not #0 as indicated in the guide.
Michael G - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 127
crwdns2942667:0crwdne2942667:0 5,978
