Logitech MX Revolution battery Replacement
  1. Logitech MX Revolution battery Replacement, battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech MX Revolution battery Replacement, battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the mouse feet carefully with a flathead screw driver.
    • Also you can buy new mouse feet on ebay if you break them.
    • Unscrew each screw a little at a time alternating between all 4 so that the base comes off all at once.
  2. Logitech MX Revolution battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift off the top of the mouse as the bottom and top are connected with a ribbon cable.
  3. Logitech MX Revolution battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech MX Revolution battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ribbon cable GENTLY use your flat head screwdriver to pry up each side of the black clip evenly until the ribbon releases.
    • At this point, the mouse shield should be free from the mouse board.
    • If you have an older model mouse, follow steps 4 to 7.
    • If you have a newer model mouse, jump to steps 8.
  4. Logitech MX Revolution battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery retainer. Use your flat head screw driver to pry up the metal tab as it is quite flexable.
  5. Logitech MX Revolution battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech MX Revolution battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery by pushing the tab forward and lifting the battery at the same time.
    • You can see the part number for the battery.
  6. Logitech MX Revolution battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery cage with your Philip's screw driver.
  7. Logitech MX Revolution battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your flat head screwdriver, wiggle the connector until it comes off.
    • Insert the new Li-ion battery L-LY11 and you are done.
  8. Logitech MX Revolution battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech MX Revolution battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech MX Revolution battery Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This step is for the newer model mouse.
    • Insert the new Li-ion battery L-LL11 and you are done.
  9. Logitech MX Revolution battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech MX Revolution battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech MX Revolution battery Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Extra pictures from Logitech Revolution MX.
    • The mouse use Omron D2FC-F-7N micro switch.
crwdns2935229:027crwdne2935229:0
tommy
crwdns2935283:006/21/12crwdne2935283:0
111 crwdns2915208:0crwdne2915208:0
Only one correction.
Either way you can order the new LY battery, since it's manufacturing date is newer and there's been some fix in it.
You just use a toothpick to take down both old and new switches, and mount the old switch on new battery. Takes 10 min and steady hands.
I just did it, and the things working....
Ivan Almas - crwdns2934203:0crwdne2934203:0
Thanks for the guide.
I would not just order the LY battery. This depends on your manufacturing year. The LY battery has wires soldered onto it, but the old model does not have wires soldered onto it because there are contact points on the battery holder (like an old cell phone battery). Just open your mouse to be sure. Old model uses the L-L11 battery.
One tip: for the old model you don’t need to unscrew/remove the battery holder. Just take the battery out.
agrior -
Pro Tip on reassembly: attach the ribbon cable from the upper shell before reinstalling the battery cage. The battery cage makes it extremely difficult to slide the ribbon back into the slot.
If you work carefully, it may be possible to skip disconnecting the ribbon and battery cage altogether.
Rob Winger - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 98
crwdns2942667:0crwdne2942667:0 36,024
