Logitech MX Mechanical Mini Akku tauschen
  1. Logitech MX Mechanical Mini Akku tauschen, Akku: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Entferne den Aufkleber auf der Rückseite des Gerätes in Höhe der linken unteren Ecke.
    • Tue das gleiche mit der rechten Ecke.
  2. Logitech MX Mechanical Mini Akku tauschen: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Sei vorsichtig beim Ausbau der Klappe, da die 3 Halter leicht abbrechen können.
  3. Logitech MX Mechanical Mini Akku tauschen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ziehe das Kabel ab.
  4. Logitech MX Mechanical Mini Akku tauschen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Der Akku ist mit doppelseitigem Klebeband am Gehäuse befestigt. Hebe ihn vorsichtig mit einem Spatel oder breiten Schraubendreher ab.
    Thanks for this guide. Saved me from throwing out a keyboard (the MX mechanical full0size) that has plenty of life left in it. This battery is stuck down far too well... I used a pair of iFixit "credit card" battery removers left over from a MacBook battery replacement. You'll need to cut a tiny sliver off the long edge of the scraper, then it fits the battery compartment perfectly. I worked from the end opposite the connector, using one remover as a wedge to keep the gap open and the other as a cutter to cut through the adhesive tape bit by bit. Solvent helps as well.
    Francis Bell - crwdns2934203:0crwdne2934203:0
    @stefanpoersel is it worth adding the standard warning about working with lithium batteries at the top? It's a safety issue if someone tries to pry the battery out with something sharp and starts a fire.
    Hi @fidgety,
    good point. The tape is really sticky. Getting it off the case is ok, but nearly impossible to peel off from the battery.
    Do you have a bullet proof phrase that we can add as safety precautions?
    Br,
    Stefan
    Stefan Pörsel -
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
Stefan Pörsel
crwdns2935283:012/09/23crwdne2935283:0
299 crwdns2915208:0crwdne2915208:0
Thank you for posting this. I just picked this keyboard up today and decided to watch a disassembly video on YouTube during which the individual reported that the battery was sealed into the back plate of the keyboard which caused me to consider returning it to the store. Clearly he didn't look under the label. Glad to see it's at least serviceable!
Jared S. - crwdns2934203:0crwdne2934203:0
Thanks for posting this. This guide also works for the MX Mechanical full-sized keyboard.
Where'd you find the replacement battery? Google search only seems to turn up some sketchy looking sites.
Christopher Larrieu - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 111
crwdns2942667:0crwdne2942667:0 2,287
