Logitech MX Keys disassembly guide
  1. Logitech MX Keys disassembly guide, Logitech MX Keys: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech MX Keys disassembly guide, Logitech MX Keys: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rubber-feet from the underside
    • The three up top are necessary for this step, but we'll be removing the bottom three later, so best to do them all at the same time
    • Unscrew the three screws behind the top rubber feet
    • Note the leftmost screw is offset to the right, and not in the center
    • In my case the adhesive physically covered the screws - Lightly press with a small Phillips [PH 0] and you'll find them
    • Use a plastic opener to remove the cover
    Bottom three feet are not blocking any screws or clips, they can remain.
    There is a plastic film covering the screw holes, it can be peeled back and replaced.
    Cristina Vasco - crwdns2934203:0crwdne2934203:0
  2. Logitech MX Keys disassembly guide: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech MX Keys disassembly guide: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech MX Keys disassembly guide: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery. Note it's lightly glued on the underside.
    • Unscrew two (slightly larger, silver) phillips screws that secure the PCB
    • Unscrew the last small black PCB screw on the top right corner
    • Remove the orange tape securing the serial cable (put it to one side, you'll need to put it back if reassembling)
    • Remove the small jumper with twisted red/black wires coming from it
    • Carefully lift the serial connector (it's hinged) and lift the data cable up and away
    • Remove PCB
    Can you please insert some basic info about the battery? Like how many mAh ie.
    Gunnar Arneby - crwdns2934203:0crwdne2934203:0
    Search for Logitech 533-000177
    VauWeh -
  3. Logitech MX Keys disassembly guide: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove last PCB screw
  4. Logitech MX Keys disassembly guide: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech MX Keys disassembly guide: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech MX Keys disassembly guide: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew all the black screws along the top (9)
    • You'll have to remove the "head" of the keyboard which is attached with latches that click in. Use a plastic tool to help. It should separate completely from the keyboard.
    Remove 9 black screws in order to remove the circuit/battery housing.
    Filip van Hoeckel - crwdns2934203:0crwdne2934203:0
    Remove six silver screws, too.
    eMjay1805 - crwdns2934203:0crwdne2934203:0
  5. Logitech MX Keys disassembly guide: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech MX Keys disassembly guide: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech MX Keys disassembly guide: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be careful trying to separate the layers of the keyboard. You may damage the backlight guide.
    The back is glued to the metal baseplate and needs to be removed using a spatula in order to expose the screws.
crwdns2935229:019crwdne2935229:0
Marts
crwdns2935283:002/16/22crwdne2935283:0
426 crwdns2915208:0crwdne2915208:0
crwdns2947412:019crwdne2947412:0
Do you know how I can turn the keyboard backlight so it stays on, even if if t runs down the battery faster.
I really need that back light. I am willing to risk breaking my keyboard for the reward of having the light. If I am really lucky changing the circuit to add a manual switch for that dang back light :)
I have basic skills and I am still learning...
Thank to all the Content Makers and Fix-It guide makers...!
perhaps I could find the correct voltage for the light and prob with a test light to find the circuit for the back light with out damaging something important, like the old days_?
nazo - crwdns2934203:0crwdne2934203:0
Put a cover over the right top LED (green when turned on) - this is also the "window" for the ambient light sensor. By making it "dark", the backlight will be fully on when your hands are close to the keyboard.
Riaan Du Toit -
Hello,
Excellent tutorial!
Could you show me where the 2 red and black wires are connected (data cable I think)?
Mine got cut by accident.
Christophe - crwdns2934203:0crwdne2934203:0
hey, please look at Step 3 and you will see the red and black cables you are looking for
Marts -
Hello, the front and back plate are made from plastic or metal ? thank you
raduadyi - crwdns2934203:0crwdne2934203:0
the front and back and made from plastic
Marts -
Hello,
i spilled my keyboard, i clean everything, but backlight transparent layer broken, maybe do you know where i can buy this spare parts ?
Thank you.
Sorry for my bad english.
remjok - crwdns2934203:0crwdne2934203:0
i don't think you can buy parts from logitech. i would say the best place to try is ebay
Marts -
Thank you, i don't know about Logitech, but nothing - ebay, nothing google search result...
But thank you for this your tutorial.
remjok -
only one key is not working what to do ??
Sangram keshari beja - crwdns2934203:0crwdne2934203:0
What are you using to put back those rubber pads on the bottom? Special Glue?
Boerni - crwdns2934203:0crwdne2934203:0
No, just some double-sided tape is enough for this - The pressure added from the weight of the keyboard will keep it in place, and once it's fully adhered, it won't move because the force is lateral (being recessed) 😁
Mike Page -
Be careful NOT to use Isopropylalcohol in the Transparent/Plastic/Plexiglass thing for the Backlight diffusion plate INSIDE the Keyboard. It will absolutely destroy it.
EDIT: It is I believe PETG and not resistant to IPA.
Recep Gürbüz - crwdns2934203:0crwdne2934203:0
Everything is glued. Clearly don't want you to repair your own keyboard. Never buying logitech again.
David Boucher - crwdns2934203:0crwdne2934203:0
I missed two keys I dont know why, "1" and "3" on numerical layout.
Will this have any kind of repair?
Cristiano Alves - crwdns2934203:0crwdne2934203:0
I had a tiny coffee spill on left part of my MX Keys Mini keyboard. I Thought I got everything dried off, but seems some made it into the key section. The spill was not over main-board but at end with battery. After this, the keys F1, F2, F3 F4, 1, 2, t, i and 'caps lock' did not function. I thought it was a strange combination and have attempted to open and clean inside keyboard in vain the hope that it is mostly mechanical damage. So far no luck... Can this be a burned electric component, due to shortage at one or more keys with coffee? Wonderful keyboard, but perhaps a little more fragile than its sturdy feeling suggests ...
TLA - crwdns2934203:0crwdne2934203:0
Where does the other end of the long red cable connected to the small black screw goes?
Jorge Sierra - crwdns2934203:0crwdne2934203:0
Hi! Does anyone know what type of glue is used to hold together the plastic back panel and metal plate? Looks like double sided foam tape with paper base but I'm not sure.
Sad_serpent - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 64
crwdns2936753:07crwdne2936753:0 343
crwdns2936753:030crwdne2936753:0 1,371
crwdns2942667:0crwdne2942667:0 61,140
