Logitech MX Keys Key Removal and Replacement
sitarane
crwdns2944107:0crwdnd2944107:0sitaranecrwdnd2944107:0crwdnd2944107:0crwdnd2944107:06crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Dzi 3, 2025crwdne2944111:0
crwdns2931287:03crwdne2931287:0
crwdns2937585:0crwdne2937585:0
crwdns2944444:0crwdne2944444:0
crwdns2942287:0crwdne2942287:0
Useful for rearranging the layout, or cleaning a key if it doesn't move right.
  1. Logitech MX Keys Key Removal and Replacement, Take out key: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert something thin under the top of the key.
    • Apply a little force. It comes out easily.
  2. Logitech MX Keys Key Removal and Replacement, Anatomy of a key: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech MX Keys Key Removal and Replacement, Anatomy of a key: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Anatomy of a key
  3. Logitech MX Keys Key Removal and Replacement, Put key back: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech MX Keys Key Removal and Replacement, Put key back: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide in bottom first
    • Gently push the top part in. It clips easily.
You've successfully removed and replaced a keycap on your Logitech MX Keys keyboard.
crwdns2935229:016crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
sitarane
crwdns2935283:009/10/15crwdne2935283:0
800 crwdns2915208:0crwdne2915208:0
crwdns2947412:024crwdne2947412:0
Do you think the clips are durable?
Joshua M - crwdns2934203:0crwdne2934203:0
No, they break easily.
ikomrad -
Where can I find the keys for the replacement? I can only find keys for like $15 per key...
Fritz Freund - crwdns2934203:0crwdne2934203:0
I need to know this too!
ikomrad -
If you are having sticky key issues, take the key out, clean out the area beneath the key, and underneath the key, and reinsert the same key. In most cases, this will fix your issue. This may happen if debree/dust gets in-between the keys.
Gitesh Agarwal -
I broke off my CMD/Alt key, is there any way to fix this?
mpwehendriks - crwdns2934203:0crwdne2934203:0
People on ebay sell the keys a few bucks a piece - usually pulled from other boards.
Joshua Wowk -
where to find the spares keys for French keyboard MX key mini please; many thanks for your help
fethy ALLOUCHA - crwdns2934203:0crwdne2934203:0
Hello Fethy,
You can get French Azerty Keys for your Logitech MX Keys or Mini on eBay here :
https://www.ebay.fr/itm/276149212552
Thomas.fixit -
Do not use cleaning slime on this kind of keyboard (the brightly coloured putty designed to pick up little crumbs and dust). It gets trapped under the keys and does not come out without a lot of messing. I speak from experience and I post this here to save someone else the same hassle.
Mario Miniaci - crwdns2934203:0crwdne2934203:0
this might help you if you did what I did, and pull up from the bottom -> https://www.laptopkeys.com/KeyboardKeys....
Matthew Horwood - crwdns2934203:0crwdne2934203:0
SOOOOO,.. yet another example of Climate Change being a fraud. I'll explain; Logitech and Amazon claim they are "Climate Pledge friendly" .. but Logitech still won't sell a replacement key set for MXKeys but they will sell me an entire new keyboard that I don't need. .. the MXKeys key caps are seriously thin..I literally wore through keys in less than a year. WE WANT REPLACEMENT KEYS (wouldn't this be truly climate friendly instead of just marketing nonsense ? (I even tried 3d printed key caps but they eventually break due to Logitech's intentional crap design where keys need 0.1mm plastic anchors.
sanity inAcone - crwdns2934203:0crwdne2934203:0
key damage, want to replace ' V ' key
Radio Resident - crwdns2934203:0crwdne2934203:0
This helped a lot, thank you!
gelbertukan - crwdns2934203:0crwdne2934203:0
I had a small drop of apple juice beneath my zero key, which caused the cap to stick when pressed down a little too hard. I removed the cap and cleaned underneath. Now it works fine again.
The hooks did not break, but they have some stress marks. I would not recommend removing the caps unless absolutely necessary. Be careful when cleaning, as the black paint on the frame can easily be scratched off.
josh - crwdns2934203:0crwdne2934203:0
need to REPLACE keys - the letters/numbers have disappeared/faded from keys! where do I get replacements? thanks
lighthsecats - crwdns2934203:0crwdne2934203:0
Logitech, FFS, can't you see how many people would like to have replacement keys? Your keys wear out very fast, and it's totally illogical to buy them at third-party prices on the Internet! Be climate friendly, for once!
Luca Boschetto - crwdns2934203:0crwdne2934203:0
The issue here is to find the keys. I have 2 MX Keys and I had to cannibalize one to substitute the keys. Keys are really fragile, very thin.
And I agree with the others that you can find keys for a very high price in ebay but it's not worth the money, with 5 keys you buy a new keyboard :-)
I had the sticky issue too.
Massimiliano - crwdns2934203:0crwdne2934203:0
I had a keyboard replaced due to the keys being worn out. They new one is worse than the old. Please can we get new keys.
TGRAH - crwdns2934203:0crwdne2934203:0
Are replacement keys for the MX keyboard available?
Craig B - crwdns2934203:0crwdne2934203:0
I thank the OP for the well-thought out solution. But half of my MX Keys are sticking and it's really affecting productivity. If I try to remove and replace nearly 20 keys, I know I will break the clips on at least half of them. Might as well just spring for a new keyboard.
I need to disassemble the keyboard so that I can bust out the small tools and Q-tips for a serious deep clean. Does anyone know how to take this marvel of Swiss engineering apart? I suspect there are screws under the rubber feet that are holding the chassis together, but I haven't tried to remove the feet for fear of damaging them. I do have the plastic tools to do it. I'd appreciate any suggestions!
Sava - crwdns2934203:0crwdne2934203:0
I am looking for a replacement shift key and ctrl key fir my MX Keys keyboard (Graphite).
Noson Rabinovich - crwdns2934203:0crwdne2934203:0
Any advice on doing this for the backspace key? IT has a metal costar bracket, but can't work out where it is meant to attach to?
Nunzio Gambale - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 67
crwdns2936753:07crwdne2936753:0 525
crwdns2936753:030crwdne2936753:0 2,074
crwdns2942667:0crwdne2942667:0 54,459
