Unfortunately, the left mouse button was 2x "sucked out" (button & the plastic pin over it)
Solution: Swap the button on the left with the mouse wheel button and - n small piece of office clip - for reinforcement - melt into the bottom of the pen.
YahooOoO - Looift widerer! Addendum: "mouse wheel click" Works by the way also - because there small springs ensure that the button does not "stick" in the pressed state
Loosen the Phillips screw in the bottom.
The plastic holder of the mouse buttons is loosened by carefully pressing the two plastic closures in the middle.
The motherboard is just plugged in and can be carefully removed forwards and upwards.
Sensibly, first clean everything (dry).
Now click the button for "Links" with the button below the mouse wheel. The solder joints are huge and easy to get even for beginners.
Everything should click together again and screws can be screwed back in. -> Loooift.
Repeat the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
