Logitech M720 Micro-switch Replacement
  1. Logitech M720 Micro-switch Replacement, Dissembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech M720 Micro-switch Replacement, Dissembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech M720 Micro-switch Replacement, Dissembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Begin disassembly by removing the battery
    • Peel off the sticker underneath the battery to reveal the small Philips screw underneath. As my particular mouse had already been disassembled, the sticker is not shown in the images
    • Using a flat blade screwdriver or similar instrument, peel off the rubber pad at the upper edge of the mouse to reveal two more screws
    • Unscrew a total of 5 Phillips head scews as marked
    como has quitado los tornillos? lo estoy intentanto.. pero es imposible!!
    Lucas Walkowicz - crwdns2934203:0crwdne2934203:0
  2. Logitech M720 Micro-switch Replacement, Separating top and bottom housings: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently separate the top and bottom parts of the mouse, being careful not to pull the two parts too far apart, so as to avoid damaging the small ribbon cable that connects the switches on the top housing to the main board
    • Un-clip and remove the ribbon cable from the main board as shown. The two parts of the mouse are now separate
    • The connector on the main board is much smaller and more fragile than the connector at the other end. It would be better to leave the small end alone and unclip the big end.
  3. Logitech M720 Micro-switch Replacement, Removing scroll wheel assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech M720 Micro-switch Replacement, Removing scroll wheel assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech M720 Micro-switch Replacement, Removing scroll wheel assembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the clip holding the translucent scroll wheel assembly to the black plastic piece
    • Lift of the scroll wheel assembly, making sure not to loose the two small springs underneath, towards the front. The springs were already missing in my mouse, but I have marked the location in red
    • Remove the two screws holding down the black plastic piece, to which the scroll wheel assembly was attached
  4. Logitech M720 Micro-switch Replacement, Main board removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech M720 Micro-switch Replacement, Main board removal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech M720 Micro-switch Replacement, Main board removal: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift off the main board and place it gently to the side, taking care not to damage the remaining ribbon cable attached to a small switch and bracket assembly on the bottom housing
    • Unscrew and lift off the metal bracket. The ribbon cable and small piece of PCB at it's end should now be free
    • Make sure not to lose the small plastic on-off slider switch cover, which should now be free to fall out if the bottom housing is turned over
  5. Logitech M720 Micro-switch Replacement, Desoldering micro-switches: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech M720 Micro-switch Replacement, Desoldering micro-switches: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech M720 Micro-switch Replacement, Desoldering micro-switches: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Desoldering Pump
    $3.99
    • Identify and de-solder the micro-switch solder pads using your preferred de-soldering method, such as a solder pump or de-soldering wick. Your soldering iron tip should be clean and properly tinned, unlike my atrocious tip pictured here
    • If required, pry the old switches off with a flat-blade screwdriver while applying heat to the solder pads
  6. Logitech M720 Micro-switch Replacement, Switch replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech M720 Micro-switch Replacement, Switch replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech M720 Micro-switch Replacement, Switch replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Install and solder the new switches
    • Again, be sure to use a correctly tinned and clean soldering iron tip. Your tip should not be as gnarly as mine is in these pictures
crwdns2935229:017crwdne2935229:0
Santaji
crwdns2935283:003/25/11crwdne2935283:0
1.231 crwdns2915208:0crwdne2915208:0
crwdns2947412:07crwdne2947412:0
Next time show ALL screws, type and position.
On this mouse screws are not all similar and if somebody forget that your “guide” don’t help
John Travolta - crwdns2934203:0crwdne2934203:0
Thanks for the guide! It helped so very much.
The_Rural_Juror - crwdns2934203:0crwdne2934203:0
thank you! i only needed to open and clean the dust inside and it clicks well again.
mine was double clicking when i click and hold.
was about to unsolder and swap the left and right switches but didn't have to go all the way there.
screws are fine i think. just be careful and put them on a safe place with the same relative positions to make it easier to put back, as with all other devices when disassembling.
UPDATE: mine is double clicking again 1 month later, and just found out recently from reddit that breathing humidity to the switches will often fix the double clicking problem with these Omron switches inside. it's magic! i tried and it really fixed it.
ted - crwdns2934203:0crwdne2934203:0
Just replaced mine m720's switches with Kailh GM 8.0 Mouse Switches, working like charm!
Dishendra - crwdns2934203:0crwdne2934203:0
Wow. I read your comment and bought some Kailh GM 8.0 switches. They are really awesome. It's such a great mouse to use now. Thanks for such a great recommendation.
Edward Furey -
My problem is two fold 1) mouse wheel way too loose; 2) intermittent disconnect while scrolling
Michael - crwdns2934203:0crwdne2934203:0
I love this mouse—it’s the only Logitech model with Easy-Switch buttons on the side. However, the MX Master 3s has the buttons on the bottom, which is inconvenient. I attempted to open the micro-switch and adjust the spring, but unless you have steady hands, it's nearly impossible. My advice: follow the instructions carefully.
That being said, the guide’s instruction to reassemble in reverse order is misleading. One issue I encountered was the on/off switch. It’s tricky to realign the notch on the board. I missed it the first time and couldn’t reassemble the mouse because the switch was slightly elevated. I had to disassemble everything and start over.
Also, the two tiny springs under the scroll wheel should be mentioned more clearly in the instructions. They’re very small, and even slight pressure can cause them to jump out of place.
Syah Hill - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 128
crwdns2936753:030crwdne2936753:0 560
crwdns2942667:0crwdne2942667:0 24,601
