5 Schrauben lösen, die teilweise versteckt sind. Drei Schrauben befinden sich unter den Gummipuffern und eine im Batteriefach unter dem Aufkleber (den sollte man dann vorher lösen)
Den blauen Trackball kann man einfach aus seiner Halterung herausdrücken. Das sollte man auch gelegentlich tun und die Öffnung reinigen.
Nachdem die Schrauben gelöst sind, lässt sich das Gehäuse leicht abheben. Die Aufnahme für den blauen Ball besteht aus einem eigenen Stück Kunststoff. Die Platine ist mit einigen Schrauben befestigt.
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
crwdns2935229:014crwdne2935229:0
crwdns2947412:09crwdne2947412:0
Had an issue where the left clicker was not working great anymore. Followed this guide to take it a part did a little blow out and some rubbing alcohol to for now restore it to the proper working condition! Thanks as I would have never found the screw under the battery sticker.
Great! Thanks for the feedback - it's really motivating
Hi, the middle click on my M570 was working really bad, sometimes works sometimes not.. but after open the mouse and apply isoprophilic alcohol with a soft brush in the middle switch (the square with red central button), it is working like a charm again.
Thanks for the information. I am happy you could use the information
More than happy to find this manual, as I was asking official Logitech Support and no positive answer. I disconected the tape between teh upper and lower part - any tips how to reconect it?
I would also never find the fifth the screw under the battery sticker.
Thank you for the positive feedback. I have no idea which connection is missing. I suspect it might be related to the connection between the small circuit board that is screwed or attached on top of the main circuit board. Unfortunately, I can't provide any specific advice on that. I hope you manage to fix it. Maybe you can share here how you did it once it's done.
Great manual. I wanted to give my mouse a deep clean and this helped to get me through. There was a tricky step separating the clicker from the circuit board, but if you are careful you can see how it fits together. Be patient and you'll get it in.
Thanks for your reply - really motivating to write more ;-)
I still have a couple of M570’s which don’t work as well as they used to - despite regular removal of the ball and cleaning that - and its internal pick-ups. I might try peeling off all five rubber pads and battery sticker for a thorough clean inside, then use a drop of superglue to re-apply rubber pads - but just to one side of their original recesses, for future access to the clamshell screws…
