Logitech M215 Battery Replacement
  1. Logitech M215 Battery Replacement, Remove the battery cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech M215 Battery Replacement, Remove the battery cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech M215 Battery Replacement, Remove the battery cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
    • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
    • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
    The battery lid lifts up from the back. It does not slide back.
    Bob Peters - crwdns2934203:0crwdne2934203:0
    U need to keep clean…& battery compartment needs gently pried off. Make sure to put back lid cover, pushing down on black prong..OR will not make contact.
    cconradmoore - crwdns2934203:0crwdne2934203:0
  2. Logitech M215 Battery Replacement, Remove old battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
    After replacing battery light goes on then off. I tried it twice. Do I need a new part.
    Elsie Sarkisian - crwdns2934203:0crwdne2934203:0
    After replacing battery the remote green light goes on then off. I tried it twice
crwdns2935229:028crwdne2935229:0
Hannah Pate
crwdns2935283:001/30/15crwdne2935283:0
1 742 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-1, Watkins Winter 2015 crwdns2935289:0USF Tampa, Team 1-1, Watkins Winter 2015crwdne2935289:0
USFT-WATKINS-W15S1G1
crwdns2935297:028crwdne2935297:0
crwdns2947412:010crwdne2947412:0
I disassembled this exactly as stated and now I can't get the cover back on?
Rei Peterson - crwdns2934203:0crwdne2934203:0
I am a electronic technologist and this is a poor design for a mouse. No wonder the later version is different.
Joseph Wonderless - crwdns2934203:0crwdne2934203:0
Thanks for the information. It worked perfectly for me. Easy removal. Images and instructions were very helpful.
Tracy Moore - crwdns2934203:0crwdne2934203:0
The green battery light went on, although the lazar light did not. What should I do?
Susan Petho - crwdns2934203:0crwdne2934203:0
well this is a bit horrible, because i don’t have an extra AA battery.. and i have a M325, but the battery life is dead..
Diana Lee - crwdns2934203:0crwdne2934203:0
I struggled to get the lid off until I realized that the lid lifts up from the back, it does not slide back. Once I found that out, it’s quite easy to open and close.
hey! the battery is like stuck, how do i get it out? anyone?
angie - crwdns2934203:0crwdne2934203:0
Sachin Tripathi - crwdns2934203:0crwdne2934203:0
great help ,easy when you know how
Tim OBrien - crwdns2934203:0crwdne2934203:0
Your post is beneficial. I can follow it can change the battery of the M215. If you have any posts, I will read all of them because I'm spacebar clicker
Hanry Han - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 14
crwdns2936753:07crwdne2936753:0 73
crwdns2936753:030crwdne2936753:0 265
crwdns2942667:0crwdne2942667:0 120,262
