Follow this guide to replace the scroll wheel on a Logitech M185 wireless mouse:
The scroll wheel is one of the most important parts of the mouse, controlling the scrolling function while web browsing. Often, due to dust or other buildup, the scroll wheel stops functioning, leading people to discard their mouse. This guide will allow you to bring your mouse back to life and use it for many more years.
This repair requires removing the motherboard from the mouse to access the scroll wheel. Avoid touching the motherboard directly. If possible, use ESD-safe gloves while handling the board and/or hold it only by the edges to prevent damage.
Turn your mouse over so the bottom is facing up.
Slide the battery compartment door off to reveal the battery.
Remove the battery.
Use a Phillips #00 screwdriver to remove the single screw in the battery compartment.
Place one hand on the bottom of the mouse and the other on the top. Gently remove the top of the mouse.
Use a spudger and gently pry the motherboard up, to remove it from the mouse.
Carefully remove the scroll wheel from the motherboard.
Replace the motherboard.
Gently but firmly press down on it until it is securely in place.
Put the top of the mouse back onto the bottom and press them together so they connect.
Use a Phillips #00 screwdriver to replace the single screw in the battery compartment.
Replace the battery and battery cover.
